Question about RCA 32V524T TV
Television I have a rca television model 32v434tyx5, and my screen reads unusable signal, can you tell me how to fix it? , I call my cable company and the cable is working.
  • Anonymous Nov 30, 2008
    I can not get the sat to work with my tv. I get unusable signal also.
  • tagstheboss Dec 17, 2008
    I have rca sdtv #32V343TH and when I tried to hook it up to digital cable it first said unusable signal, I finally got it to pick up some channels but it's only some local and not cable channels and the channel numbers aren't the same as the other tv in the house.
  • 390 Answers
Hello
Both cable tv and satelite tv have a converter box that the signal is put out on channel #3. What you have to do is just have the converter box's output cable wire going to the tv's analog antenna input, the tuner in analog mode and on channel #3 for it to work.
Posted on Feb 10, 2009
  • 790 Answers
Hi
ca you tell me what is exactly trouble in your television!?
Thanks!!!
Posted on Jun 22, 2008
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
My rca tv has unusable signal onit
Hi, Check the cable connections to and from the TV.
Change the channels to see if there are others that are out.
If you are not using any cable company then you will still need a set top box to unscramble the digital signal. Good luck.
Jun 06, 2012 | Televison & Video
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
Guide Plus on RCA television
My guide quit working also on my RCA 61" big screen and I called the cable company and he said something about the encryption data had changed and I needed to call RCA to find out what to do and the whole time trying to sell me a converter box. It is the cable company's fault or the guide wouldn't have put that message up to start with. We all need to call the FCC!!!
Dec 04, 2008 | Televison & Video
Unuseable signal
WHAT HAPPENS WHEN YOU USE A DVD INPUT (AV) OR A SAT/CABLE BOX CONNECTED TO THE AV INPUT'S ,,IF IT CLEARS UP YOU HAVE A SIGNAL BOARD BAD BUUUUUUT YOU CAN BYPASS THAT BOARD AND SAVE MONEY JUST BY USING THE AV INPUT...TUNICA
Sep 25, 2008 | RCA P52926 52" Rear Projection Television
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
Rca rear projection model#p52926s
The unuseable signal is a common thing that rcas do when the input rf signal is No good . You could have a bad cable line an bad ant. line or a bad tuner or the set is switched to the wrong anttenna input. No for a Hd compatable componet I always start with 1080i and go from there cause thats what is needed for an hdtv set. Good luck
Apr 21, 2006 | RCA P52926 52" Rear Projection Television
RCA 32V524T TV Logo
552 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
