Question about Onkyo TX-SR605 Receiver
Onkyno receiver shuts off
My onkyno receiver shutss at about 42 decibels I just added 2 speakers to a 7.1 system
  • proggyt67 Jun 26, 2008
    I've got the same issue as Ozzy right now, but I dont see any consistency in when it shuts off as far as the decibel level. It seems to be anywhere from 50-70db. My sub isn't hooked up yet (forgot the cables) so not sure if that may be part of the issue. I have not done the Audyssey set up either as the room is empty (no carpet or furniture) until Tuesday 7/1 and in reading the manual I got the impression the room should be in the condition it will be used in before doing that.
Onkyo revievers of that era got real hot. There needs to be several inches of clearence above the unit. Check the manual for clearences. The shutting down is because of too much heat. They will also shut down if there isn't enough load ie: too low ohms. You need atleast six ohms per channel for most home equipment. Tring to split out the amp to multiple speaker pairs will require an impedence matching selector.
Posted on Jun 16, 2010
My SR605 gets extremely hot. This is especially true when both amplifiers are running together supporting 2 separate channels. I added a 2 way speaker selector from Russound that supports 2 sets of 8 ohm speakers on Zone 2 and the receiver shuts down at about 74 dcbs and gets very hot. Checked the jumpers on the selector and they are set at 8ohms.
Have returned the Russound selector to them and had it checked out. Appears to be fine. Even when Zone 2 is not in use the receiver gets extremely hot. It is in a wood cabinet wih glass doors but even with the door open the temperture is very hot. As the volume is raise the heat increases and the receive trips off.
Very unusual in my opinion. Is this normel for the receiver to heat up as the volume is increased.
Posted on Jul 27, 2008
Receiver wont hold memory, all levels go to zero when turned off
I'm not sure about this receiver, but it has one of three things, batteries on the back of the unit(very old school) a battery backup inside the unit, or a Super Capacitor(capacitor backup around 1f).
If you are interested in having your Denon repaired, please visit my website at audioserviceclinic.com. Thank you.
Aug 29, 2015 | Denon AVR-591
The system is overheating
Jul 27, 2008 | Onkyo TX-SR605 Receiver
Zone 2 doe's not work Ihavetwo speakers that are outsde they are zone 2 when a am to the tuner I press zone 2 ad it shut off
Possibly a shorted speaker wire? If you remove zone 2 does the amp still shut down? If not, connect one side at a time and try it. Do you see the word protect on the display when it happens?
Aug 04, 2014 | Denon AVR-1908
My center speaker connection is faulty?
There should be some fault to internal output circuit.
May 11, 2013 | Philips Audio Players & Recorders
How do i hook up external speakers to my sanyo plasma 42 inch hd tv
if there are jacks in the back of your sanyo you can hook up 2 speakers if your sanyo do not have external audio RCA jacks for speakers...you will need a home entertainment receiver to hook up the 2 -7 speakers...
Jun 21, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
I had seven speakers hooked up and went to a 5
check all your speakers and wiring. remove any unused cables from receiver. use the setup mic and it will do the rest
Dec 07, 2009 | Pioneer VSX-815-K Receiver
Why do the volume numbers on old receivers start
This type of calibartion is known as a logarithmic scale.
The numbers refer to decibels below the maximum output of the amplifier section of the reciever, or decibels of attenuation (making smaller/quieter).
Without going through logarithim theorey, the logarithim (base 10) of 1 is 0. So if 1 is the maximum output of the amp, as you turn the knob down from maximum you are adding more and more attentuation to the output (relative to maximum) and so the loudness of what you hear goes down, even though the number on the scale is going up !
Most peolpe associate decibels with sound levels, but anything can be measured in decibels, so long as there is soemthing to reference it against.
Nov 04, 2009 | Pioneer VSX-D409
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
203 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
