Samsung My tv set will be on for an hour and half and then it looks like an xray and begins to flicker, and then we cannot watch it anymore. We turn it off for an hour and then we turn it back on and can watch it for another hour and half. Any suggestions?? Thank you
  • 2,071 Answers
The problem of your projection TV ,is most in vertical section ,is need to re solder all joint of the solder its already crack or cold ,,when cold solder occured in your unit that is cause abnormality delivery of current and voltage that its the problem of your TV if this problem not remedied,it can cause burnt of spare parts due cannnot supress limit of the current passed;you better reheat the all vertical section ; horizontal section ;and to jungle IC..find a tv technician to do this job in avoiding high voltage shock,reheating job cannot cost too much..
Posted on Jun 22, 2008
    Brigadier General:
  • 6,966 Answers
Based on your general description, it could be:
1. loose connection or cold solder on any of the connectors and/or boards specially those related to power;
2. heat related - at some point, the heat generated inside the unit could cause a component failure or worsen a cold solder/loose connection;
3. a component is about to fail - on most Samsung projection TVs, this would be the DM board. Exhibited symptoms would be screen flickers (white flashes) and in some instances after about a minute the screen gragually turns very very bright (almost white) from the bottom of the screen to the top.
Any of the above would require familiarity with electronic circuitry and components, use of a DVM and a soldering iron as well as access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable venturing into a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 3,037 Answers
The first thing to check are the capacitors, see if the tops look bulging. They are the cylinder looking things on the board. Let me know if the tops are smooth and rounded and we can go from there to narrow down this problem. Basically a board is probably over heating and need of replacing. Please don't rate this solution until you are satisfied and reply as soon as you check the capacitors and I will get back to you as soon as I can.
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    If you are satisfied with your experience here, then feel
    free to provide me with some feedback by rating my solution. If you need any
    more help, I would be glad to assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • 6,487 Answers
IF this is a CRT TV you better try checking the picture tube of this one because the symptoms pointing to a bad tube already then better take it to a repair center near so it will be properly diagnose by a professional of this unit and for your safety also..
Good luck......
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
I have a Philips 50 DLP HDTV MICRO DSPL and I figured the lamp was about to go out because after you would watch tv for about an hour and a half the picture would begin to flicker so I replaced the lamp...
A couple of things to check here. When you replace a lamp some TVs require you to reset the lamp hours meter in the settings in the menu (More common in projectors). If you do not do that then it will only run so many hours before shutting off again. If it is that, you should be able to turn it off and have enough time on the screen to reset that. If that is not the case then you should look into replacing your power supply board.
Aug 23, 2014 | Televison & Video
Problems with colors and display on my Samsung LN37A550P3FXZA flat LCD.
Replace all busted capacitors in power supply board inside.
Jan 10, 2014 | Televison & Video
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Screen Flicker then tv shuts off
please re solder  first all parts specially in hot area, and observe if problem still occur, then next is replace filter capacitor. observe also too hot parts and check for change value resistor.
Feb 25, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a 51 inches big screen TYPE # AC120-60HZ-200W and after watching TV for about a hours or less the TV begins to flicker and the picture gets hard to see, so we shut it off. And after waiting awhile...
First look in the back and be sure that the fan is turning and that the airway is clear. There are airflow sensors inside that may be shutting down the set because they are dirty and can not detect the flow correctly or the lamp may just be getting too hot. Normally there is an indication on the front of the set with a flashing code. Look for that and try to match the code with one listed in the owner's manual.
Keep us posted.
Dan
Aug 01, 2008 | Televison & Video
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Flickering Screen
soon the picture going to go to black screen, you got somes capacitors bothering, you better to call a tech now that he can see the problem, later will cost you more..good luck ps the picture many times tell to the tech whats going on.
Aug 07, 2006 | Samsung HC-R4755W 47" HDTV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
