Question about Garmin eTrex GPS Receiver
Etrex vista cx
Compass arrow has left, and has not come back, even with 2 fresh battery changes, and 2 calibrations of compass.
  • asaxist Jun 25, 2008
    Already did that. Several times. Turned off waited 30-120 sec, tried again. no luck.
    Problem Solver:
  • 6 Answers
Hi, the DOT (Direction Of Travel) arrow will only appear on the Compass page when you are navigating.
  1. Go to the 'Main Menu'
  2. Select 'Find'
  3. Select 'Waypoints'
  4. Select a waypoint
  5. Select the 'Go TO' button
Once you are on the Compass page you should have the DOT arrow as long as you have a sat lock.
Posted on Jun 24, 2008
How do I calibrate my compass in the eTrex Venture HC. The book says to go to the tje menue and then press calibration. My GPS does not give me this option.
I will be happy to help you with this. Unfortunnately, the Etrex Venture does not have an Electronic Compass, therefore you cannot calibrate it. What this means is that this unit will show the correct direction of travel as long as you are moving. The unit takes satellite reading every 1 seconds and compares it's location with the last location. This way it can read the direction of travel. It will not give correct readings unless you are moving.
I hope this helps.
Dec 31, 2009 | Garmin eTrex Venture HC GPS Receiver
Garmin etrex vista Cx won't lock onto a position. Reads multiple satilites bit won't genrate a position.
Have you tried fresh batteries? Weak batteries, I've noticed, can cause this problem. Also, try to acquire your signal in a clear area (no trees or power-lines nearby)
Jul 29, 2009 | Garmin eTrex GPS Receiver
Compass in 3 parts on the screen
This is normal! The compass looks like this in "course pointer" mode.
When you're looking at the described compass screen, press the lower left button and notice the line "bearing pointer". When you select that line and push the front joystick, you'll notice that the compass needle is "normal" again . And when you push the lower left button again, you'll see that the line has changed into "course pointer". Pushing the joystick again toggles between those two modes. The shifted needle indicates how far you drifted from the course that your route follows. See page 31 of the English manual for details.
Jean-Marc Bouyeure
Jun 20, 2009 | Garmin eTrex Vista HCx Handheld GPS...
I just purchased a Garmin Etrex Summit GPS receiver. The function that I most need is the Sight 'N Go, but when I access the pointer page options list the Sight 'N Go option is 'greyed out', although the...
It is greyed out when the electronic compass is off. Switch it on by holding down the top right button for 2 seconds. A confirmation message flashes up on the screen.
Apr 19, 2009 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
Compass deos not point north
do a calibration. press the menu button while on the compass screen and select calibrate.
Jun 07, 2008 | Garmin eTrex GPS Receiver
Garmin etrex
This is a problem with the garmen, however, sometimes if you can remove the battery, and leave it out for one hour, then replace it while facing north outside, it usually re adjusts itself. also sometimes if you can reset the unit that will also sometimes bring it around. if that doesn't do it, I suggest contacting garman tech support, it may have to be sent in to have the software updated or it can be a defective unit, if it has been dropped., or gotten wet.
Garmin HCx GPS unit
The Vista HCx has an electronic compass. You don't need to be moving for it to work, but you do need to calibrate it. To calibrate the compass:
  1. Go to the Main Menu
  2. Select Setup
  3. Select Calibration
  4. You will be asked "Which Sensor Would You Like To Calibrate", select Compass
  5. You will see a page that says "To Calibrate Compass: Slowly Turn Two Full Circles In The Same Direction While Holding The Unit Level", select Enter and do this.
You need to hold the unit level for the Magnetic Compass to work correctly. The specs for a properly calibrated compass are +/- 5°
May 15, 2008 | Garmin eTrex Vista HCx Handheld GPS...
Compass dosent work
The compass is very sensitive. Anything magnetic will intefere with its ability to calibrate. Try taking the unit outside, far away from anything metallic, and lay it down on a flat level surface, then follow the compass calibration procedure. Make sure you rotate the unit clockwise and turn it very slowly. If that doesn't work, you could have a defective sensor.
I'm not sure what you're using the compass feature for, but on mine I disable it. It draws the batteries down faster and I find that my track, or course over ground, is more reliable than the compass heading. The only real advantage to the compass is if you want to get a bearing while you are standing still.
Feb 08, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin MAP 60CSx
try calibrating the compass. make sure the battery type is set to the correct type.
Nov 12, 2007 | Garmin GPSMAP 60CSx
Garmin eTrex GPS Receiver Logo
102 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
