Problem with t.v
Red tinge to screen, and menu screen to far right of screen, so cannot read the menu screeen properly to try and fix problem..........(little 2 year old hands playing with t.v)
  • 790 Answers
Hi
you have defective RGB Circuit and vertical allignment!
Thanks!
Posted on Jun 22, 2008
I am trying to set my Sanyo picture right side up. what setting do I go to?
Check Ceiling feature.
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT button(s) to move a red-frame pointer to
SETTING icon.
Language used in ON-SCREEN MENU is selectable from among
English, German, French, Italian, Spanish, Portuguese, Dutch,
Swedish, Russian, Chinese, Korean and Japanese.
Display
This function decides whether to display On-Screen Displays.
On ··· shows all On-Screen Displays.
Off ···· sets On-Screen Displays disappeared except;
? ON-SCREEN MENU
? "Power off?" message
? "No signal" message
? "Please wait...."
? P-Timer counter
Set a red frame pointer to item and press SELECT button.
Press POINT DOWN button to move a red-frame pointer to item
that you want to set and then press SELECT button. Se ting
dialog box appears.
Dec 11, 2010 | Sanyo PLC-XF46N LCD Projector
Red shift to left with curve at bottom
Par 2 = " I do see the convergence chips..."
Par 3 = " I'm not sure where the IC's are...."
Please verify STK part # of IC's on large heatsinks.....
And then I'll give you step-by-step instructions......T.
Nov 19, 2007 | Panasonic PT-47WX53 47" Rear Projection...
SCREEN IS HIGHLIGHTED RED, ALL WORDS READ IN RED AND THE PICTURE IS BLURRY ON PHILIPS MAGNAVOX 9P5034C101
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2010 | Televison & Video
Red tinged and blurry pictures from hp 6380 printer
Try a head clean. This is usually accessed from the printer menu on the printer, or the properties in Windows. If this doesn't work you could have faulty cartridges. This can be common with refurbished/refilled cartridges.
Dec 12, 2009 | HP Office Equipment & Supplies
Red tinge on tv screen when laptop plugged through HDMI
Neo2123 is correct.
The HDMI output is setup as a second disply, not Primary disply.
You will need to get into the video Driver settings and configure this for a single monitor.
1. Right click on the desktop
2. select "graphics properties"
3. set up the "Digital Display"
All the steps or naming may be different on you computer, but some of this is fiarly standard.
May 08, 2009 | Televison & Video
Machine is beeping and a faucet is appearing in the panel
I just fixed this fault on my SHE68m05uc. The fault lets the machine run through any cycle and every ting else was working properly. In line between the fill valve and fill float assembly there is an electro magnetic impeller which is "open" if there is no water flow. the signal goes to the timer control board on the lower right side of the machine. If you Pull the impeller, take an OHM reading across the sensor that is mounted to the side of the impeller and blow into one end. If the measurement changes as it rotates, its good. if its shorted "0 Ohms" its broke. The part was about 17$
Nov 20, 2008 | Bosch Evolution 800 SHE68M05UC Stainless...
SAMSUNG lcd tv
try resetting the cable box. If the tv menu does not cure the picture may be in need of repair.
Nov 11, 2008 | Televison & Video
56 inch Panasonic Projection TV
Hello stonehor,
Do a quick check on your cable wire. Make sure they are all pushed in properly both on the cable box and on the TV connector. What we have found is that these cable are not pushed in all the way. If this happened on both component input, you may have an open connection further back on that input board.
Best regards
circuitcity
Dec 26, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
