Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
Gaggia Syncrony Compact
LED light 27 came on with very first boot up, filled the circuit, but still flashing, will not stop flashing, water sensor? Any recommendations into fooling it into thinking it has the perfect amount of water?
Been in storage past warantee, and now I don't think I can get any help with it.
Thanks,
Amy
  • amethina Jul 18, 2008
    Thank you for taking the time to answer this. After filling and refilling the water as well as a few power up, power downs, it decided it was fine. No problems as of yet. Too long in a storage box I fear. Hopefully it will function for a while longer before we have to replace something.
  • 515 Answers
Try to make a cup of water, if you only can get a half cup then the flowmeter has to be replaced.
Posted on Jul 14, 2008
Gaggia syncrony compact digital expresso maker says fill water tank but water tank is full
Check the float in the tank that indicates the water level to the sensor. They often fail to float, solution is to either replace the tank or jam something plastic under the float to lift it to the top of its slot.
Jan 01, 2016 | Gaggia Syncrony Compact Digital Espresso...
I have a Gaggia Syncrony Compact machine which I am trying to descale. I have added the descaler to the water in the tank. when you hold down the button (26) more than 5 seconds nothing happens.What is the...
To descale the appliance proceed as follows:
• Mix the descaler with water as specified on
the package and fill the water tank.
• Switch ON the appliance with the ON/OFF
switch (7).
• Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
I noticed you did not mention the switch ON before you pushed button 26. Try that should work.
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
The led 27 flashing no stop
Hi
If you are talking about the descale light, you must let the machine quit on its own. The pump has to stop on its own. Any interruption (you stopping the machine) will keep it in the descale mode. Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
Jan 06, 2010 | Gaggia Syncrony Compact Digital Espresso...
Descaled and got 23, 24, and 27 buttons flashing
Fill water tank and open the knob to empty boiler and circuit.
Nov 29, 2009 | Gaggia Syncrony Compact Coffee...
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Compact Rote LED 28 blinkt
Try to prime your machine, if you only get a half cup of water then you have to replace the flow meter in the machine.
Jul 20, 2008 | Gaggia Syncrony Espresso Machine
If you are in decalcify circle you have to finish it before the machine goes to ready again.
When you decalcify the machine, there will comes water for a short period, then it hold up for a couple of minutes then it will run out little more water. So will the machine do to the water tank is emty.
May 18, 2008 | Gaggia Syncrony Espresso Machine
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
299 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
