TEVION TSD-DR40HD. CONNECTED TO A 16:9 PANASONIC . SAUCE SIGNAL FROM FOXTEL TUNER BASICALLY ALL WORKS BUT SCREEN FLICKERS ANS SHOWN (16:9 IN TOP LEFT HAND CORNER) AND A BLACK BOLD WORD "WIDE" I HAVE CONFIGURED (10 TIMES WITH DIFFERENT COMBINATIONS)THE RECORDER AND THE TV. ODD THING IT WILL SETTLE DOWN AFTER ABIUT 20MINS. ANY SUGGESTIONS JIM
IT APPEARED TO BE A FAULTY CABLE
THANKS
Posted on Jun 22, 2008
Tevion tdr930
The TDR930 does not have a digital tuner. It handles the PAL and NTSC video signals. You need to connect it to a set top box and then record on the Line In (composite video) input. The set top box could be a cable, satellite or digital-to-analog OTA converter. Since the DVD recorder can't record HD signal, the regular SD output converter box connected to an antenna will be good.
I wish that I had better news for you.
Jan 04, 2014 | Televison & Video
Only blue screen no signal top
Check its input signal cables for firm connection. Check its tuner, if it do not recieve on-air transmission.
May 02, 2013 | Panasonic Televison & Video
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
Panasonic viera TH50PZ700B 4yrs old. will turn on and begin auto search however does not find channels, sky aerial cables connected. the screen goes to customer id but as soon as a button on the remote...
Tries tv unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.Go into the tv menu go to PICTURE to go down to do a resetting to the tv Tuner signal board.Tries scanning for channels again.The tv should be work again,if it still have the same result.The tv main board,the tv Tuner signal board is bad.Can u do some mechanicals work like take things aparts and putting it back together again?Yes?Try website like Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 15, 2011 | Panasonic VIERA TH-65PZ700A 65 in. Plasma...
I HAVE A PANSONIC FLAT SCREEN HD/TV..I DON'T HAVE A MODEL\r\nNUMBER. MY PROBLEM A RED SHADOW APPEAR ON THE SCREEN WHAT CAUSES THAT TO HAPPEN
This tv is have a dying CPU chip on the tv Tuner signal board.That the board,that take in the tv incomming broadcasting signal cable,that plug into it.Can you do some basic mechanical work like take things aparts and replaced it with another parts.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Mar 14, 2011 | Panasonic Televison & Video
Picture on my Panasonic PV-DF2700 flickers and then there's a blue screen. Cable company says signal is going to TV. Is the TV history?
Hello, the tuner could be ready to go out entirely, but you can still view your cable TV through your Auxiliary input jacks(video/audio colored jacks) most of the cable boxes ave these outputs in the rear all you need is the RCA cable(yellow/red/white) and select the video input you want to use. The other solution is to replace the tuner. You can order one through www.partstore.com or directly from panasonic at their website www.panasonic.com.
Nov 26, 2010 | Panasonic PV-DF2700 27 in. TV/VCR/DVD...
Panasonic Viera link and Foxtel IQ
It is very likely that cross talk does corrupt the link but for Panasonic to "blame" anyone else is not very professional. Anyway, if it worked for 6 months perhaps disconnecting the Foxtel IQ and reestablishing the Viera link with the Panasonic devices then reconnecting the Foxtel IQ for another 6 months of happy viewing. This is not a permanent solution but the alternative doesn't seem to be an option.
Feb 26, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
1- I have a Panasonic TV (PT-53TW54)that has a "digital scan rate of 1080i,540P". I'm not sure if that means it has a digital tuner. Do I need a digital converter for this unit? 2- I'm using a...
1. Do I need any additional equipment to watch HDTV broadcasts on my HDTV-compatible TV?
In order to view over-the-air (OTA) HDTV broadcasts, you need to be within the reception area of a TV station broadcasting HDTV signals. Some TVs may require a set-top HDTV tuner and an external antenna to receive the broadcasts. Your cable or satellite provider may also offer HDTV channels as a part of their service, eliminating the need for a separate tuner. Please contact your local service provider to find out what kind of HDTV services they may offer.
2. What is CableCARD and how does it work?
HDTVs with CableCARD slots can accept a small card from your cable provider that allows you to receive standard definition and high definition digital broadcasts without a bulky set-top cable box. Please call your cable company to find out if they offer this service in your area.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif3. What is HDMI? Is it compatible with DVI?
HDMI, which stands for "High-Definition Multimedia Interface", is the consumer electronic industry's first connection capable of transmitting uncompressed digital audio/video signals. Components featuring HDMI can transmit both digital audio and video over one convenient cable, replacing the tangled mess that resides behind many home theater components. HDMI also offers improved quality over traditional analog connections thanks to all-digital transmission. Digital sources like DVDs and HDTV programming can now be transferred digitally from source to display without analog conversions that can degrade the original signal.
Unlike the HDMI interface, DVI only handles digital video. Through the use of an adapter, a DVI device can be connected to an HDMI device, but only video content can be transmitted. The audio signal would have to be transmitted through other methods such as analog RCA outputs or an optical digital output.
4. What's the difference between 720p and 1080i HDTV broadcasts? Does my CRT projection HDTV support both?
HDTV signals can be broadcast in either 720p and 1080i. It's up to the broadcaster which signal format to use, and both have their benefits. Our CRT projection HDTVs display 1080i signals in their native format. For 720p broadcasts, you can use the settings on your HDTV set-top tuner, cable box, or satellite tuner to convert a 720p signal into a 1080i signal that your TV can display.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif5. Why do I still see black bars on my widescreen TV when viewing certain widescreen DVDs and HDTV broadcasts?
Your widescreen TV has an aspect ratio of 16:9 (1.78:1), which is the aspect ratio of HDTV. However, movies are filmed at several different aspect ratios, including 2.35:1. Also referred to as "scope", 2.35:1 is a very panoramic aspect ratio that provides a wide field of view in the theater. Scope is much wider than your widescreen TV, so it still requires the use of letterboxing ("black bars") to fit the entire image on screen. Some TVs and DVD players have a zoom function that allows you to blow up the image so it fills the screen, but the sides of the image must be cropped in order to do so.
6. What will 4:3 broadcasts and DVDs look like on a widescreen TV?
There are multiple settings for adjusting the appearance of 4:3 material on Panasonic widescreen TVs. It can be viewed with black bars on the sides, preserving the way it was originally intended to be viewed. Some viewers find the black bars distracting, so they might prefer one of the stretch modes that lets you fill the entire TV screen with the image. One such mode is the JUST (justify) mode, which stretches only the outer portion of the picture while leaving the center untouched.
Oct 21, 2008 | Panasonic Televison & Video
I purchased a Tevion tsd-dr40hd on the 23.5.08, i am a disabled pensioner and $400.00 is a lot of money for me to save. I had to wait some time until i could afford a home theatre technician to install it...
i had a similar problem, with another tevion model, earlier this year. i was able to resolve it by getting in touch with Pebble Electronics, (they handle the tevions). you might start by emailing your details to info@pebble-ltd.com.au.
hope this is of some help.
Sep 09, 2008 | Televison & Video
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Electro Med Services...
