Question about Amana AER4311AAW Electric Kitchen Range
Up and Down arrows don't work
We have an Amana AER4311AAW that we can not adjust the temperature above the preset 350 nor can we adjust our time on our clock up or down. The up down arrows seem to be not working as they control both above stated functions. Can we just replace what is called a rocker switch or do we need to replace the entire clock unit (this is what the technician told us at a tune of $200)
Thanks
Mark
  • DadofLSG Jun 23, 2008
    Thanks for your quick response. Fixya is a great resource and it in now in my the top of my favorites file!!!
  • 413 Answers
The clock (Oven controller) will have to be replaced. This part is easily replaced by removing the top rear panel. It can be purchased on-line through Sears @ http://www.searspartsdirect.com for $136.79 plus tax and S&H.
If you need further assistance please let me know..
Regards;
reg501
The FixYa Team
Posted on Jun 22, 2008
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Difference between thermal fuse and thermal switch
A thermal fuse blows (opens) when the temperature is above the set value. When is blows it will have to be replaced before the circuit is operational again.
A thermal switch deactivates the circuit until the preset temperature is reached or deactivates a circuit that is too hot.
Dec 14, 2011 | Amana NDE2335AY Electric Dryer
I dont know how to use the oven properly. when i need to bake or roast something i want to put in my own temperature, but there is no option for me to do that. when i turn on the stove all i have is the...
There should be a plus/minus sign OR a up/down arrow to adjust the temp.on the control/touch panel. The default setting is usually 350 and can adjusted up or down accordingly,the display starts at 120 and is supposed to rise as temp. increases.
The bigger issue though is to have it serviced and see why it doesnt rise above 200
Gene
Aug 04, 2011 | KitchenAid KEHU309 Stainless Steel Dual...
I have a VPT24-1PZ 24 hour programmable timer.My question relates to after you progam the astronomic clock there is an off set option to add or subtract time from the sunup/sundown time.By pushing the up...
The timer lets you adjust the preset astronomic time for your area.
This is because actual local times vary.
If the preset time for dusk is 8:00pm and you add 12 minutes, then the timer will turn off-or-on at 8:12.
And then you can change the preset time for dawn by adding or subtracting.
If this is not what exactly you are asking, then set your timer and see what happens, and then add a comment with your findings.
Open following link to download on-line manual
http://waterheatertimer.org/Leviton-timers.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Leviton Hardware & Accessories
I sthere a way to calibrate my oven temperature? It is off by about 35 degrees. Temperature is lower than display.
Sorry to read about your problem, I hope this helps you out.
To Adjust the Oven Temperature (do not use Bake or Broil while adjusting the oven temperature): note: Your oven control was factory set in the (Fahrenheit) °F Temperature Display Mode. To change for (Celsius) °C, see page 15.
1. Press & hold the BAKE key pad and release after the display shows the factory temperature setting of 00. note: If the oven temperature has been previously adjusted from the factory setting, the current temperature adjusted value will appear in the display instead.
2. You may increase the oven temperature in 5°F (1°C) increments with each press of the uP arroW pad to a maximum oven adjustment of +35°F (+18°C). You may also adjust the oven temperature downward in 5°F (1°C) increments with each press of the doWn arroW pad (total range of -35°F to +35°F (-18°C to +18°C).
3. If you do not want to keep the display adjustment, press the clear oFF pad before the oven control beeps. This will cancel the temperature adjustment procedure. To start this procedure over again begin with step 1 above OR;
4. If you want to keep the adjustment, wait until the oven control beeps once.
5. The oven temperature adjustment has be accepted by the oven control and the display will return to the time of day.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire FEB24S2AB Single Oven
The oven does not heat to the set temperature. It is usually much hotter
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Nov 15, 2010 | Amana RanARG7302 Gas Kitchen Range
Whirlpool Gas Range Model: WFG361LVB Hi I just got this gas oven about a month ago and the top burners work, broil works and bake seemed to work once or twice where i would see the temperature rise and...
Remove power. Go to the back of the oven control and remove the multi plug, check for corrosion, clean contacts, and reconnect securely. Check the ribbon connection between touch pad and control board (if applicable). Retry
Jan 21, 2010 | Kitchen Ranges
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Amana AER4311AAW Electric Kitchen Range Logo
93 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
