Question about Samsung SyncMaster 910MP 19" LCD Monitor
Record tv from monitor to computer
Is there a way to record tv programs from the monitor to my Gateway 5676 computer?
    Champion:
  • 293 Answers
Hi..there,
Of course you can...If you got a tv-tuner card installed in your pc. Then you can record any tv programs...
Posted on Dec 12, 2008
Gateway fpd1530
If you have the appropriate cable to connect the output port of the computer to the input port of the Flat Panel TV every thing will be OK. For optimum performance you might have to install the drivers for the replacement flat panel.
Nov 01, 2013 | Gateway FPD 1520 15" Flat Panel LCD...
How do you record audio with the Gateway model ZX 6961 computer?
hi, you can do a standard sound recording under Programs -> Accessories -> Entertainment. Select Sound Recording.
Oct 15, 2013 | Gateway Zx6961 G620 Touch Screen...
Gateway 5676 / loud fan how to access innards to clean with canned air?
First turn off the computer and unplug all of the cables from the back (and front ports). Then remove the two large screws that hold the left side panel in place. These are on the back of the computer. (One is even with the power supply; the other is in line with the expansion slots). Then slide the left panel back about 1/2" and pull it away from the computer. Now you can clean inside the computer.
For pictures of where the thumbscrews are, see http://support.gateway.com/s/CASES/GERSHWIN/3507057Rfaq2.shtml .
Remember to ground yourself to the computer by touching a metal part of the case when you move around the computer.
I hope this helps.
Jun 04, 2011 | Gateway GT5676 Desktop PC
Gateway monitor 22"
I think the guys at www.securedata.biz have a fix for that.
Jul 11, 2010 | Gateway FPD1975 19" LCD Monitor
Composite connection on Gateway Desktop
They are Video and Audio for connecting device together
  • Yellow = Video
  • White = Audio - left channel
  • Red = Audio - right channel
the connectors on a Desktop PC from the graphics card will be an OUTPUT-possibly labelled TV output, so what ever is displayed on your monitor can also be sent to a TV or recorder etc The connectors on the Xbox are also OUTPUT and designed for connection to a device which has the same connection but for INPUT
Your monitor may have composite inputs and allow you to switch to those Some TVs will have those connections as inputs and you would select one of the AV options to see the signal, often a separate button to choose AV input /HDMI / PC etc Some DVD and Video also have these as an INPUT as video cameras often have that type of connection - to record the signal
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Gateway GT5453E Refurbished AMD Desktop...
Gateway vx730 monitor in windows98 Not support
If the monitor isn't showing you the computer, than try Fn F4 which will switch the screens. Sometimes the computer has a default monitor and thinks it is already plugged in. By pressing Fn F4 you switch the monitors settings to display the second monitor plugged in (in your case the Gateway vx730 monitor) If this doesn't work then it would appear to be a error with Windows 98 not having the right programming to support the monitor.
Hope this helps ^^. Please don't forget to rate, Thanks.
Feb 24, 2010 | Gateway VX730 (Platinum) 17 in.CRT...
No signal from computer to monitor 8/13/08!
I had the exact same problem!! Drove me crazy for days. Couldn't find any answers online, contacted Gateway tech support and they told me my warranty was expired but they'd be happy to discuss my issue for $2 per minute. Gateway can **** it!!
At first I thought the problem might be a malfunctioning NVIDIA card, a problem with my DVI cable, or the monitor itself. But, after turning off the computer, unplugging the DVI cable, replugging the DVI cable and restarting the computer, I noticed I could get the firmware flash screen to show, including the BIOS menu boot and the Gateway system reinstall screen to show. As soon as the Windows flash logo would display, however, the monitor would drop out and display the dreaded "No Signal" error.
This indicated the problem was a software one and not hardware! The cable, monitor and video card were all working fine. Then I remembered that Windows installed its automatic update a few days prior. In fact...
THE PROBLEM TURNED OUT TO BE A WINDOWS UPDATE INSTALLED A FEW DAYS PRIOR.
After succesfully booting into safe mode (F8 during the flash/bootup screens), I went to Add or Remove programs in the control panel, clicked on the "Show Updates" box on the top, and uninstalled the Windows update from a few days prior to the occurance of the error. After a reboot the problem was solved.
I hope this will help anybody else struggling with this error!
Aug 15, 2008 | Gateway FPD2185W 21 in. LCD Television
Connecting Gateway HDMI TV to Playstaion 3
If your PS3 has HDMI capability and the monitor has HDMI capability, it should work as long as the monitor can match to the specs of the PS3.
I am not sure, but I think the PS3 required the capability of 1080p from the TV set. Make sure that your TV is able to see 1080p.
For HDTV, the standard A/V cable set is of no use. That is why your monitor probably does not support the standard A/V format.
Jerry G.
May 18, 2008 | Gateway FPD2275W LCD Monitor
Samsung SyncMaster 910MP 19" LCD Monitor Logo
87 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
