I looking for a wireless mouse of the same brand as the wi-fi.
  • 37 Answers
I'm afraid I have never heard of a wi-fi mouse however there are bluetooth mice that work on the same frequency band (2.4Ghz). Google or Ebay would be the best site to look for one!
- John
Posted on Jun 22, 2008
HP wireless mouse AOX35AA how do I connect, does it require a usb
It connects via wi-fi; no USB connection is necessary if your computer supports wi-fi.
If you need a manual, you may download one at http://h10032.www1.hp.com/ctg/Manual/c02823195.pdf
Oct 13, 2016 | HP Computers & Internet
Wii-fi will not turn on
Let me know the device you are using
Jul 13, 2015 | Google Android
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
How to customize wireless mouse
If you're asking about how to customize a wireless mouse, we'll need the make and model of the wireless mouse in question. Usually there's some form of "calibration software" that might be available for your device.
Also, "wireless" in relation to your computer's network connection isn't the same thing as wireless when it relates to a wireless mouse.
Wireless mice use Bluetooth or Infra-red for transmission, not the same wi-fi as your computer's networking/internet.
Good Luck!
Oct 17, 2013 | Edimax WRLS ADAPT| USB EW-7317UHG RT...
Laptop model number R50e how can i use wifi
What brand of Latop acer , toshiba , compaq , dell ,????
Do you have a wireless modem ?
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
One of the features that makes laptop computers desirable is their ability to connect to Wi-Fi networks, thus allowing people who are on the go to be able to check email, browse the web or update social networking status any time they are in a Wi-Fi hot spot.
Fortunately, enabling Wi-Fi on a laptop is simple to do.
Only basic Internet and computer expertise is needed to connect your laptop to a wireless network.
Click on the "Start" menu on the bottom left-hand side of your desktop.
Then select "Control Panel."
When the "Control Panel" window opens, choose "Network and Internet."
Click on the "Connect to a Network" link that is found underneath the "Network and Sharing Center" heading.
A new window will open.
Choose "All" from the drop-down menu and click the "Refresh" button on the right side of the window.
A list of available Wi-Fi networks will appear in the window.
Click on the Wi-Fi network you want to enable on your computer.
Then click on "Connect."
You have now enabled Wi-Fi on your laptop.
Click on your web browser of choice to browse the Internet.
Sep 08, 2013 | Computers & Internet
What does need a data connection mean
To use Google maps or some other programs (like games), you need to be connected to a Wi-Fi network, not the cellular network. You will need to be in an area with an open wi-fi network or have a wireless router in your home. Find your password for the router's wi-fi network (it should be password-protected) and the SSID; you also need the encryption type (WAP, WEP, etc.).
Press Apps on the Home Screen. Then press Settings and then Wi-Fi. Select Scan to locate available networks. While on the Wi-Fi tab, press Add Network. Enter the SSID with the keyboard, then touch Security type to select the encryption for your router. Then enter the password and finally press Save. (Some wi-fi routers will want the MAC address before you can add a device to the network. Go to the Menu - Advanced from the Wi-fi tab to get the information.)
If the wi-fi network has been set up on the Tab, press Apps on the Home Screen. Then press Settings and look for the Wi-Fi On/Off icon. Toggle this to on. (You can also access this by touching the time on the Home Screen. Then touch Wi-fi on the Quick Settings list.)
I hope this helps.
Jan 16, 2013 | Samsung Galaxy Tab 2 7.0
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Computers & Internet Logo
David Payne
David Payne
