Steps to Unlock a Password Protected Memory Card of Your Mobile PhoneThe steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer,
After finished downloading, install it to your mobile phone.
Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
Run FExplorer and open the following location C:\system.
From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
When you finished the above steps, you will find the password of that file.
follow the steps: 1.To unlock your mobile
memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar 2.After finished
downloading, install it to your mobile phone. 3.Insert the mobile
through phone at this moment. 4.Run FExplorer and open the following location C:\system. 5.From the location
C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt. 6.Copy the file mmcstore.txt. and paste it to your computer. Now, open
that file in notepad. 7.When you finished the
above steps, you will find the password of that file Rate me if this is helpful. Good Luck :)
if you have a memory card reader (if you dont have get it from a friend)connect the memory card via the reader to the pc which has an original antivirus system. after the icon appears, right click on it and click on format. this will delete all the files in the memory card. i suppose you should have removed the card from the pc connection when a file is being transferred. after the memory card is formatted the cellphone wont show such message.
Kindly try the following as a fix for your problem:
Attach it to a memory card reader linked to your PC, then search the root files and look for a file called mmc. when you find the file it will have a symbols and lines, you need to find any sequence of letters or numbers. Copy those and paste them unto your phone as a password.
hello... your problem suggests that your memory card is corrupted and i dont think u can recover a corrupted memory card. buy a new one n try not to inserting/removing a memory card carelessly n frequently. its better to format your working memory card through ur mobile phone than wid pc software but if it struck then try to use card reader n format it through ur pc just like any other removable disk drive n for Nokia N72 the memory card's file system is only FAT and not FAT32.
buy a new one .but next time when u want to format ,connect to pc suite via pc and then select memory card and delete file by file but never delete an instal program otherwise it will be corrupt again.so if u want to delete instal promgram ,go to tool / application manager and delete it from here.
