My machine will not rinse cloths. The cycly stops once it gets to rinse and it makes a lite buzzing noise.What could it be?
  • 413 Answers
Most washers today are cold rinse only. The buzzing noise you hear may be the cold water valve.
1. Check cold water to make sure it is on.
2. Remove cold water hose from back of machine. Inspect washer cold water valve for debris. Can usually be cleaned with spray bottle with hard spray.
3. Cold water valve has failed.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
Posted on Jun 22, 2008
Why is my Whirlpoo WFW9050X washer buzzing when it's turned on?
Biggest hassle with these machines is that the belt or drive stops working properly. Check for that first. If parts needed check here. Search Over 2 1 Million Appliance Parts
Sep 09, 2017 | Whirlpool WFW9050X Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Rinse cycle doesn't work
Your cold water valve is clogged. Most likely needs to be replaced or at least cleaned.
www.oc-repair.com
Feb 09, 2010 | Kenmore 22422 Top Load Washer
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Clothes washer makes big noise after wash cycle
sounds as though you have a blockage in the pump/hose system stopping the water from getting out quick enough. check the filter out first.
Apr 05, 2009 | KitchenAid Washing Machines
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
It makes buzzing noise and doesnt work
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
click the link http://www.repairclinic.com/0088_11_1.asp#Level1_5
Dec 11, 2008 | Kenmore 24902 Top Load Washer
Kenmore Elite Calypso Washer
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Mar 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
My washer is making a buzzing noise and stopping the process.
Yes sounds like the drain pump or sump area is clogged. Axcess throug lower service panel if the model you has selected is accurate..
Jan 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
