Question about U-Line Icemaker
Water leaks into storage bin
Unit works fine except water drips continuously forming large ice cycles and eventually makes storage bin one large chunk of ice. Already adjusted water level in tray to make the smallest cubes. Please help. Thanks Chet
    Problem Solver:
  • 27 Answers
Open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Posted on Jun 24, 2008
  • Greg Zeck Aug 26, 2014
    Good if you could write clear English.
Amana ASD2626HEB ice maker leaking into bin
either there is ice formed inside the fill tube where the water goes into the ice maker and spraying all over the place when the ice maker tries to fill, or the ice maker mold is cracked letting it leak out.
Jun 03, 2012 | Amana Refrigerators
Ice maker is leaking water at the rear of the ice maker, somewhere around the water inlet. Water is dripping slowly and building up an ice ***** BEHIND (outside) the ice cube storage bin AND inside the...
Hello,The reason all the ice freezes together and you see icecicles forming from the icemaker,is going to caused by the water inlet valve on the back of the refrig.is not fully closing but instead it's seeping water through it and dripping into the ice storage bucket. To stop that from happening the water inlet valve would need to be replaced.
On refrigerators that have a built in water filter,alot of times their will be 2 water valves and the one that is bad causing water to seep through it will be the one called the SECONDARY valve.
GENE
Sep 30, 2011 | Maytag MSD2454G Side by Side Refrigerator
Ice maker leaks or runs over Causing big chunks of ice in the drawer
It's very possible that the water inlet valve isn't cutting off completely. I had that to happen on mine.
Mar 17, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have a model SS6SHAXMB00 side by side Refrigerator Freezer. My problem is the Ice Storage Container freezes into a solid chunk of ice. We don't use a lot of ice and like to take it by hand from the...
Water may be dripping into the ice bin. If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Also the water can be diverted from the ice mold by ice blocking the fill tube if the water inlet valve is leaking.
Sep 21, 2009 | Refrigerators
Ice machine not working, I have water in the door but no ice. looks like there might be a ice buildup. I had a leak in the water line and this problem started after I fixed the water line
Is the ice buildup in the ice bin storage or ice maker. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 04, 2009 | Refrigerators
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Feb 26, 2009 | Maytag MSD2456G Side by Side Refrigerator
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Ice maker leaking
Sometimes the frozen chunk of ice in the back of your ice tub is caused by the tub being overfilled. The ice cubes pile up so high that they come in contact with the defrost heating element in the bottom of the ice maker. This melts the already formed cubes and form a blob of ice in the rear of the tub.
If the "icicle" is forming even when the tub is relatively empty, then it is probably a leaking solenoid valve. This is an electric water valve that opens and closes according to demand. Like any valve, it has seats that eventually leak, especially in areas with hard water. This will need to be replaced. Water filters go a long way in increases the usefaul life span of the valve and will also improve the ice quality.
Dec 02, 2006 | Kenmore 53642 / 53644 Side by Side...
U-Line Icemaker Logo
588 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
