Question about Mitsubishi WD-52525 52" Rear Projection HDTV
MITSUBISHI BIG SCREEN TV
The TV has been working fine today the the on/off switch won't work. The light comes on for a few seconds and turns back off. Can you help????
Please - Any suggestions would be wonderful!
  • DLPLBP Jun 22, 2008
    Thanks! We're going to look into it. Appreciate you help.
  • Bellmore3689 Jun 23, 2008
    TV comes on few a few seconds then turns off
  • Mitsubishi Master
  • 8,617 Answers
That sounds like the capacitor issue on the PWB PCB there is a kit for that available at the following link that includes all the capacitors and the borad location numbers of where they go, and it cost less than half what a repair tech would charge just to come look at it. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 22, 2008
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I have a Mitsubishi TV model WS-48511 it was working fine, I shut it off came back a few hours later & when I turn it on the green light will come on for about 3 seconds but turns back off. What can I...
Unplug it from the wall for about 5 minutes.
with it unplugged, Press and hold the power button for around 30 seconds.
This should discharge the unit and allow it to come back on.
Jul 02, 2011 | Mitsubishi WS48511 48" Rear Projection...
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mits big screen vs-60707screen comes on red then turns off 10sec
either a bad red crt or bad transistor on the red crt pcb!
Feb 25, 2009 | Mitsubishi WT-42315 42" TV
Mitsubishi tv model wd-62531 less than 2 years old
It sounds to me like your bulb has burned out. Look behind your TV for where the bulb housing is and pull the bulb out to check if it's burned out or not. You'll know when you look at it if it's toast.
Dec 10, 2008 | Mitsubishi WD-62531 Projection Television
MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Nov 01, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi VS-5005R big screen
I just finished fixing one of this units and there a few thing that i changed, the voltage regulator and 2 capacitors and as prevention repair i did some resoldering in the power supply and horizontal ckt
good luck
caypianan@yahoo.com
Oct 29, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi TV WS-55511 Turns Off after Turning On
My mitsubishi big screen tv turns off in few seconds what should I do and I just got tv today please someone help
Oct 28, 2007 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
