Question about JVC Everio 25x/20GB Hard Disk Drive Camcorder
Camera only works when charger is plugged into the wall outlet
My camera only works when the charger is plugged into the wall outlet.But as soon as I take the charger out of my camera it will not turn on. I have tried everything... I have bought a new battery, new charger, let it charge all night, plug it into many outlets,deleted all images and video, and reset the camera. My camera has been like this for about 2 months.The camera works perfectly when plugged in but it will not even turn on when it is not plugged in.Can you help?
2 Suggested Answers
richard191
  • 691 Answers
SOURCE: My camera only works when the charger is plugged in
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 29, 2009
BATTERY CHARGER IS THIS A SERPERATE ITEM
That depends on the camera.
Some cameras include battery charging circuitry. You plug the camera into a wall outlet or a USB port and it charges the battery. Some cameras come with a separate battery charger which plugs into a wall outlet or a USB port. Some cameras use standard batteries, disposable or rechargeable. With these you need to use a separate battery charger compatible with the type of batteries.
If you're asking about a specific camera, please add a comment to your question and specify the make and model of the camera.
Sep 24, 2014 | Cameras
Where on the camera do I plug in the charger
If you're using the charger that comes with the camera, it doesn't plug into the camera at all. Take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet.
If you're using the USB cord, it plugs into the camera on the left end (as viewed from the back).
Jun 04, 2011 | Vivitar ViviCam 8025 Digital Camera
M530 Digital Camera, how to charge it
Assuming you're referring to a Kodak M530, you can charge the battery in one of two ways:
  1. Use the supplied USB cable to connect the camera to the supplied adapter, and plug the adapter into a wall outlet.
  2. Take the battery out of the camera, put it into the supplied charger, and plug the charger into a wall outlet.
If it's not a Kodak M530, please reply to this post specifying the make of the camera.
Dec 17, 2010 | Cameras
Will a usb cable fitting the Vivi Cam 8025 charge the lith battery; I can't locate a port on the camera to plug in a wall charger?
Yes, you can charge the 8025 through the USB port, assuming the computer puts out enough current to do so (not all USB ports do). Or you can take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet.
Dec 04, 2010 | Vivitar ViviCam 8025 Digital Camera
I need to charge this camera
There are two ways to charge the battery. One is to use the supplied battery charger. Remove the battery from the camera, put the battery into the charger, and plug the charger into a wall outlet. The other is to use the supplied USB cable. Plug one end of the cable into the camera and the other end into an USB port on a computer or other power source.
If any of the parts were missing when you opened the package, contact the retailer or the manufacturer directly at http://vivitar.com
Apr 08, 2010 | Vivitar ViviCam 8025 Digital Camera
My camera only works when the charger is plugged into the wall outlet.But as soon as I take the charger out of my camera it will not turn on. I have tried everything... I have bought a new battery, new...
Hello
Thank you for using
Thanks
Richard Scott
Technical Support
New Zealand
Nov 28, 2009 | JVC Everio 25x/20GB Hard Disk Drive...
Tape stuck in camcorder
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape.
Sep 03, 2009 | Canon ZR25MC Mini DV Digital Camcorder
Where to get a vivitar vivicam 8025 wall charger or car charger
It should have come with an external battery charger with a wall charger.
Check the cell phone section of a department or electronics store. You should be able to find USB chargers that plug into wall outlets or cigarette lighters. You can use one of those along with the supplied USB cable to charge the camera.
Sep 01, 2009 | Vivitar ViviCam 8025 Digital Camera
Dec 24, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
On my camera the battery charger light is blinking and the battery is not charging
Before you get creative and directly plug your batter into an AC adapter, try something much easier first. I have the same problem with my Olympus 770SW batteries. As silly as it sounds, the charger will only work in a select few outlets in my house that I found by trial an error, actually pure frustration. I suggest, go around your house and plug the blinking charger in all the outlets and see if you find one that works. That sounds a lot less shocking than solution 1 and 2 now doesn't it? Good luck!
May 23, 2008 | Cameras
JVC Everio 25x/20GB Hard Disk Drive Camcorder Logo
128 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
