Repeating 's' key
Thanks for answering but I forgot to mention the fact that the keyboard is a laptop! Do you still have the same answer or is there any chance that it could be another solution to my problem.
  • buggerfun Jun 24, 2008
    Thankyou I will also give you feedback on the outcome. But this does sound like the likely solution. The detailed information on how to do this is great. Thanks again.
    Novelist:
    Scholar:
  • 70 Answers
Well...slightly different :) The reason is still the same. The solution is slightly different.
The keyboard for almost all laptops is also a plug-in and is separate from the rest of the unit. You usually have to remove the front frame from the screen to remove the top frame for the keyboard and the laptop. Screws to do this are often covered by stick-on circles of plastic or rubber. They may even be covered by labels on the back. This helps the manufacturer know if it has been tampered with to determine warranty. If it is out of warranty then do whatever needs to be done.
Removing the frame around the keyboard there will be screws holding it to the bottom frame or motherboard. Once you have removed these then there is a flat mylar cable that is connected to the motherboard, usually at the top. Putting your thumb and index finger around the connector, pull towards the keyboard. It should slide just a fraction of an inch and the flat mylar cable will be free. So will the keyboard. Now, you might be able to take the keyboard apart from the back (lots of small parts may fall out!) You can look for anything spilled or any debris on the part and try to clean it. You can use rubbing alcohol to remove any obvious spills (Coke or other cola products are especially an issue).
Connect it back up (push the cable back in the cable and reverse the process. You don't have to put back on all the frames to try it.
If the keyboard is still having problems try to get a replacement on ebay. The most expensive part of a laptop is the screen (around 200 to 500 usually). I got an entire non-working laptop (just for parts) for $75 once. You should ask the seller if the keyboard was working before you buy it. Good luck, hope this helps.
Posted on Jun 22, 2008
How do I switch on wireless capability on an acer laptop travelmatep453?
On Acer laptops, wireless capability can be enabled by using a combination of keys on the keyboard. In most of the Acer laptops, there is also a dedicated wireless switch located on the top of the keyboard. The icon representing this dedicated switch can vary depending upon the model. To know more about this, you can refer to the guidelines mentioned on the link below:
http://acer.custhelp.com/app/answers/detail/a_id/1304/~/enable-or-disable-wireless-networking
GuruAid.com
Mar 22, 2015 | Acer Computers & Internet
Turn fn key
There is a "Fn" key next to the "Ctrl" key on the left of the keyboard.
Keep it pressed when pushing on one of the funktions on the top of the keyboard (next, play, stop, ...).
If this answers your question, please mark this as "Answered".
Oct 08, 2013 | HP 4440s Probook
Keyboard
please be patient and answer the questions.
Is the keyboard typing all by itself or not?
thanks so much
Sep 15, 2012 | Gateway Id47h02u Notebook I5-2410m {intel...
How do i enable bluetooth in Toshiba laptop c660-1TE
Hello angel,
You can enable and disable Bluetooth by pressing Fn + F8 (Press and HOLD Fn key and while still holding the Fn key press F8 key). You might need to press it repeatedly until you see the Bluetooth is ON.
You can rate my answer if you appreciate my help.
Thanks!
-damneddle
Oct 14, 2011 | Computers & Internet
My Fn Key is not functioning after I reformatted the laptop. Since then, it only works fr controlling the brightness of the laptop without indications on the scree. How am I suppose to solve this...
You have to download the application for your laptop, its either on the disc that came along with your laptop or you can go to the manufacturers website to download the software.
Jul 25, 2011 | ASUS 90-A4C1K1000 Keyboard
My touchpad no longer works and some keys on my keyboard will not function including Fn therefore cannot check Fn+F7 to toggle touchpad. I'm using the On-Screen keyboard on my Acer 5610 laptop. Any...
Hi there uninstall the key board driver from the laptop, then restart it again and install the driver from acer driver disk. Bbut before these please try the step below mentioned.
1. Restart the PC and repeatedly hit F8 until you have a menu in front of you.
ebbbffb.jpg 2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
After these if you face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
Feb 15, 2010 | Acer Aspire 5610 Notebook
Im trying to reboot my dell inspiron laptop and forgot what buttons to hold when the windows image comes up. i think it was something like "cntrl+F11" but that dosent seem to be working.
Hi there, yes your right. The reboot key is Ctrl+F11.
If its not working then do these.
2. You will find few option there. Just select these mention option " Reboot" use by your up/down arrow on your keyboard.
3. Select Reboot and hit enter.
Hope its helpful.Thanks & waiting for your feedback.
Feb 13, 2010 | Dell Inspiron 6400 Notebook
G6000 hen pressing keyboard letter it type 4
Hi there
Does this happen with almost every key, or only certain keys? And if you press a key very quickly, does it still register it as 4 presses?
Also, please confirm the operating system on the laptop, such as XP or Vista.
Please do not rate this solution unless I have answered your question or your reply will not be returned to me. Thanks.
Aug 21, 2009 | HP Computers & Internet
Password will not work
may b a key board failure. Go to safemood aln check also.
When the machine boots up press F8
then go there and check. If its not a virus, it will work fine
If not you need to clean the keyboard
Thanks
Please rate the answer if it helps u
Jun 24, 2009 | ASUS Eee PC 701SD
Keyboard space bar
turn your keyboard upside down and tap it a few times. if that doesnt solve the problem repeat.
If it still won't work write back for more ideas.
good luck and please rate my answer. thanks.
Feb 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
