I recently bought an AMD Sempron 3000+ (Socket A, Barton core, 512K L2 cache) with PC Chips M825g mobo and noticed that this mobo's BIOS doesn't have a setting for enabling any CPU overheat protection shutdown.
1. Does the PC Chips M825g mobo have built-in CPU overheat protection?
2. Does the Socket A Sempron 3000+ have built-in CPU overheat protection as the Athlon64 CPUs do?
I realize that I can use MBM5 to shut down the computer in case it overheats, but I prefer protection that works even if Windows locks up. On my Duron CPU computer I have a hardware device to shut off the computer when the CPU gets too hot.
-   i need the installer drivers for AMD M825G
-   Guest
Solution #1
posted on Aug 11, 2005
Pasty - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Neither the manual nor the new BIOS (May 2005, replacing July 2004) mention anything about CPU thermal protection, and it wouldn't surprise me if this mobo didn't follow AMD specs because I found that all the fuses for the keyboard, mouse, and USB ports were replaced with jumper wires.
Oddly, the only CPU fans to give me trouble were all Deltas provided with retail boxed AMD CPUs. Years ago, five K6-2 CPUs fans squealed loudly beause their rear sleeve bearings hadn't been lubed at the factory. Every Delta fan vibrated, and the one included with my Athlon XP1800+ was so bad that I asked AMD replaced it, but the replacement vibrated the same. OTOH the same heatsink sold by Coolermaster with a Coolermaster-labelled fan was buzz-free. I was also happy that this Sempron 3000+ came with a smooth-running fan, labelled AVS.
I use an overtemperature shutoff device consisting of a quad comparator and some thermistors and have it monitor the CPU, graphics chip, and hard drives.
Was this helpful?
Yes
No
Solution #2
Mini Me - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
On 14 Jun 2005 00:09:51 -0700, "larry moe 'n curly"
We should all be thankful that the board costs 25 cents less I suppose... It's really sad how little some parts omissions save. If PCCHips had a mind to, they could take the mid-grade market easily by simply making decent boards.
Were they thin(ner) fans? I omitted that important detail, that the thin fans seem shortest lived. Thick, slow, largest diameter possible... will probably be one of the last parts to fail instead of one of the first. I still have 10+ year old Panaflos that run great, even being sleeve-bearing.
I may get motivated towards doing something like that, though at present I've been trusting the board's shutoff mechanism, and never having had to rely on it as I am quite picky about the fans I used. When sleeve-bearing, they get a special homebrew synthetic oil/grease lube that even manages to keep those crappy Yate Loon fans running after they'd seized up and fried power supplies... not that I'd reuse them, but is all part of my ongoing effort to ensure that (the odds are low) of my ever having to depend on a thermal shutdown. Funny thing is that my volt-modded FX5900 video card probably produces more heat than anything else but has the smallest fan (strapped onto a solid copper 1U Xeon 'sink). It'll probably snap in half some day from the weight of that 'sink, LOL.
Was this helpful?
Yes
No
Solution #3
Bouncy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I looked at another M825g mobo and found a green lump thermistor labelled RT1 in the center of the socket. It's not surface mount, so a pot could be soldered to it on the other side of the mobo.
Was this helpful?
Yes
No
Solution #4
Peter1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
On 13 Jun 2005 12:30:22 -0700, "larry moe 'n curly"
It should, though PC Chips is definitely a bottom-feeder when it comes to quality, so I wouldn't be overly surprised if they skimped on this sort of feature.
No, though to be fair, ALL current processors require a fair degree of help from the motherboard. The built-in overheating protection on newer chips just lets them crash slightly more gracefully, hopefully ringing some alarms before the thing locks up.
This would be normal and has been the case on virtually all motherboards produced in about 7 or 8 years now. However, as mentioned above, you never really know for sure when buying from the bottom of the barrel.
------------- Tony Hill hilla <underscore> 20 <at> yahoo <dot> ca
Was this helpful?
Yes
No
Solution #5
Gary10 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
It's supposed to, as are all boards adhering to AMD's spec for Socket A after (a certain point in time, about 3 years ago, IIRC). I can't confirm that it does though, and suggest you look again at the bios pages and motherboard manual.
No, it has a thermal diode to take temp readings, that is all. The actual shutdown mechanism (threshold) is then left with user options and implemented by the motherboard.
I would be more concerned about proper cooling subsystem design and good fan selection. It is rare for good, low RPM fans to die. Don't use cheap, off-brand (meaning anything not bearing a _fan_ manufacturer's label, not a 3rd party label like Coolermaster or Antec or ???. While those two and others do sell some products with decent fans, you don't have an assurance of the actual fan they relabeled in all cases (situations). Instead trust Nidec, NMB, Papst, Panaflo, Sanyo, Delta, et al.
Was this helpful?
Yes
No
Popular Solutions for AMD For All Sempron&Athlon XP
select the decimal written correctly in expanded form 4.9? select the correct place value for the...
(More)
SELECT THE DECIMAL WRITTEN CORRECTLY IN EXPANDED FORM 4.9? SELECT THE CORRECT PLACE VALUE FOR THE UNDERLINED NUMBER 0.0006_ 6 IS UNDERLINED? SELECT THE # that is written as a fraction correctly 34.5 1.448? select the # that is written in digits correctly one hundred and four hundredths?select the number that is written as a decimal correctly 9-10 and 3 45/100? thirteen thousandths in decimal form ? select the # that is written in words correctly 0.009 and 53.106?23.07 # written in words correctly?select the decimal written correctly in expanded form 1.06?select the # that is written in digits correctly six and four tenths?select the correct place value 1,034.22_11
