Question about Garmin GPS
Will not start - Garmin GPS
  • cmagnesi Jun 22, 2008
    I have had the Garmin nuvi 760 1 day. It appeared to be working OK. I would turn the GPS off after I turned the car off. Now, it will not start when I start the car.
  • Garmin Master
  • 6,487 Answers
You may to check the battery of it and try to charge it on a power outlet because sometimes that can cause the problem but if it doesn't work try resetting it follow this :
Try pressing the lower right corner of the screen and pressing power, leave your finger on the area of the screen (lightly, as if you're touching a touch-button) and see if this changes.
If not, try holding in the power buttin until the unit shuts off (rather than suspends) then leave it plugged into the wall charger for a few hours and see what it does...
Hope that helps........
Posted on Jun 22, 2008
  • Mark Gil
    Mark Gil Jun 22, 2008
    So that can be a problem with the battery do you have any spare battery for it so we can try it will work fine..
  • 1,183 Answers
could let me know the model and maufacturer of the device to help you better .
Thanks
Proton
  • 1 more comment
  • Mandeep  Singh
    Mandeep Singh Jun 22, 2008
    Hours of Operation
    Monday – Friday: 8 am – 7 pm
    Central time (closed holidays)
    1-800-800-1020 (U.S.)
    Try sliding the power key to the left and hold it there for * seconds .
    Try powering the device on again
    Thanks
    Proton
  • Mandeep  Singh
    Also check the Fuse in the car, if the it has not blown out and for the same reason the device is not powering on.
    The user manual for the device can be downloaded from here
    http://www8.garmin.com/manuals/nuvi750-G...
  • Mandeep  Singh
    All Garmin products are warranted to be free from defects in materials or workmanship for one year from the date of purchase. Within this period, Garmin International, Inc. will, at its sole option, repair or replace any components which fail in normal use. Such repairs or replacement will be made at no charge to the customer for parts or labor, provided that the customer shall be responsible for any transportation cost. This warranty does not cover failures due to abuse, misuse, accident or unauthorized alterations or repairs.
    In case your unit is under warranty, you can call and get help on the above mentioned phone number.
    If the unit is not under warranty , then too you can calll and send the system in for service.
    Thanks
    Brigadier General:
  • 3,614 Answers
Can you give me the exact detail of the problem, and the model of your GPS..
Thanks
Volvo v40gdi sometimes won't start but starts fine from cold when trying to start it chokes and struggles if I remove air filter assembly it starts fine,
To troubleshoot the issue, click the link below:
Car Repair Diagram
http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
HOT/WARM START ISSUE
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These details will help.
Thanks.
Mar 14, 2013 | Cars & Trucks
I have dodge ram 1500 v8 no start
CAR NO START PROBLEMS:-----
It can be the issue with weak battery or faulty battery or if battery is ok,then its faulty starter causing the issue.
From start to end troubleshooting these problem i suggest you to click the link below and follow its procedure:-----
What to Do When Car Turns Over But Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Car will start to chugg and then die and sometimes wont start , engine light comes on when this starts happening
Get the vehicle scanned,there is error code stored in ECM,that code will tell what part exactly to look,for:----
But other then these for starting troubleshooting for these problem,
These will help.
Thanks.
Nov 28, 2012 | 2000 Pontiac Bonneville
2007 Jeep Liberty won't start. See Video.
1989 Toyota Pickup Truck: Turns over but not start? http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start? http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
2001 Toyota Prius will not start? http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start? http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html ------------- Mitsubishi will not start
These will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
2001 mercury mountaineer starts fine but sometimes won't start at all
These will help.
Thanks.
Nov 25, 2012 | 2001 Mercury Mountaineer
I cannot use cheat codes of call of duty 2
Select "Game Options" at the main menu, then choose the option to enable the console. Press [~] to display the console window then enter developer 1 as a command to enable cheat mode. The "Load" button will now appear. Click it and select the desired level. After the level loads, press ~ to display the console window again, then enter devmap as a command. Press ~ during game play to display the console window, then enter one of the following codes to activate the corresponding cheat function:
god ... Player invulnerability on/off
give all ... Player accrues all weapons
give ammo ... Player accrues all current weapon ammo
ufo ... Player may swim/fly through game world
noclip ... Player may clip through environment
notarget ... Player is invisible to enemy entities
moscow ... Start on the map Red Army Training
demolition ... Start on the map Demolition
decoytrenches ... Start on the map The Diversionary Raid
decoytown ... Start on the map Holding The Line
elalamein ... Start on the map El Alamein
eldaba ... Start on the map The End Of The Beginning
tankhunt ... Start on the map Repairing The Wire
trainyard ... Start on the map Railroad Station No. 1
downtown_assault ... Start on the map Downtown Assault
cityhall ... Start on the map Stalingrad City Hall
downtown_sniper ... Start on the map Comrade Sniper
libya ... Start on the map Crusader Charge
88ridge ... Start on the map 88 Ridge
toujane_ride ... Start on the map Armoured Car Escape
toujane ... Start on the map Retaking Toujane
matmata ... Start on the map Assault On Matmata
duhoc_assault ... Start on the map The Battle Of Pointe Du Hoc
duhoc_defend ... Start on the map Defending The Pointe
silotown ... Start on the map The Silo
beltot ... Start on the map Prisoners Of War
crossroads ... Start on the map The Crossroads
hill400_defend ... Start on the map The Battle For Hill 400
hill400_assault ... Start on the map Rangers Lead The Way
bergstein ... Start on the map Bergstein
breakout ... Start on the map The Brigade Box
newvillers ... Start on the map The Tiger
rhine ... Start on the map The Crossing Point
Feb 28, 2010 | Activision Call of Duty 2 for Windows
GPS Logo
26 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
