Question about Compaq fs740 17" CRT Monitor
Compaq FS740 When I turn the monitor on it imediately goes into power saving mode (the indicator light is amber instead of green). How do I get it out of that mode
  • mich702 Oct 11, 2008
    I'm experiencing the same problem as lodi720, but nothing is happening when I press Esc or F8. Any other solutions?
    Problem Solver:
  • 6 Answers
Try pressing escape. or press f8 when your computer starts up and then press factory restore
Posted on Aug 27, 2008
Will a dell tft turn on with no source
Your monitor should turn on without a source and display the floating 'Dell - self-test Feature Check' message. If it does not, verify the power LED is on "GREEN" and indicating either power on / diagnostics mode or "Amber" power saving mode. If neither indication you have power problems. If these symptoms do not apply, shine a light on the sceen and see if there is a faint image. If this is true, you have backlight problems.
Nov 06, 2013 | Dell E173FPc 17" TFT LCD Flat Panel...
Compaq monitor FS740 is turned off after some time
Step 1:
Check your screen saver setting.
Step 2:
check your monitor setting to always in active mode.
Jan 10, 2013 | Compaq FS740 Color Monitor
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Inherited Compaq FS740 but after hooking up monitor will show green for a short time and then color is yellow? Is it dead? Has set up for a while
Check the pins on the cables. Single color presentation but clear picture indicates the pin for a particular color is borken on teh cable. Remember Red Green and Blue are mixed to make other colors. If you have predominantly one color then its due to cable not haveing all pins inserted properly or damaged.
Jun 28, 2010 | Compaq fs740 17" CRT Monitor
Compaq w17q monitor keeps going on and off how can i fix it?
1. check the power cords- make sure all are snug.
2. check and make sure no pins are bent in the cord to the computer
3. make sure that the monitor is not in auto-power save. Or in auto off mode. For example- is the light amber or green.
4. finally, make sure that your settings on your computer are not set to power off your monitor- as in a blank screen saver, power save or hibernate
Mar 26, 2009 | HP Compaq W17q Monitor
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
Monitor doesn't work
I'd try this monitor on a spare computer. It sounds like the video card (motherboard integrated or otherwise)is not putting out any video information or missing sync signals. The monitor must receive these signals or it will go into standy/sleep mode. If the computer has integrated (on motherboard) video, check your bios settings to see if it is properly enabled. If it has a slot video board, then try a different video board. Your present board might be dead. Another possibility is a bad cable connection. check the connectors for bent pins. Assuming the connector is the standard HDB-15, it is easy to bend a pin over.
May 30, 2007 | LG L1730S 17" LCD Monitor
Compaq Monitor
OK All these Compaq's have a Power Supply problem, or a Horizontal Voltage problem.. meaning they are on the way out. The SMPSU's in these units often fail along with the Horizontal Drive Circuitry. I think it is time for a new one? Repair of such a unint would barely be "Ecconomical" IMHO.
Aug 07, 2006 | Compaq fs740 17" CRT Monitor
Monitor doesnt come on , but the power light goes from amber to green. then comes on after 20-30mins maybe.
Maybe update your display drivers. PC appears to be slow.
Make sure you don't have a bunch of apps that auto start.
Do you hibenate your PC?
Same issue if you connect monitor to another PC?
If issue follows you to a different PC it says monitor. If it doesn't it says the first PC (that monitor is currently connected to) had a cpu/memory or a driver issue.
Good luck
Oct 25, 2017 | Sony SDM-HX93 19" LCD Monitor
Compaq tft 5005
Did the same and burnt a frazzled chip. it is on the 3rd circuit board (I believe it provides the lamp power). It is the 8 pin surface mount chip next to C900. As far as I can make out, the numbers on the chip are 4559 **** **7B I was told it's the lamp drive. If it is indeed lamp drive, then when you turn the monitor on, round the edges of a flashlight pressed to the screen, you should see a picture. If there isn't one, you may have killed more than I did. Is there no power regulator at the input? Good luck
May 18, 2006 | Compaq TFT5000 15" LCD Monitor
Compaq fs740 17" CRT Monitor Logo
376 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
