Question about Compaq Computers & Internet
I have a computer hooked up to bell sympatico. How do I connect my new compaq to it? Thanks
  • 3,940 Answers
If you have only a DSL or Cable modem, that doesn't have an integrated Router, then you'll need to get a router to use more than one computer. The broadband modem, will connect to the uplink port of the router, and give you usually 4 wired ports and up to 50 wireless connections.
Here is an example from linksys
Posted on Jun 22, 2008
How to Configure Belkin routers for Centurylink, Embarq, Bell sympatico, Bell...
How to Configure Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
Configuring Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs :
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Do not connect the modem to the router.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router i.e.,
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
We need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on LAN settings (found on left side of RSP), change the IP address from to and save changes.
Step 3: Now Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using another Ethernet cable.
***Once you are done that, you need to re-login to RSP by typing the new IP address in the address bar of web browser.
Step 4: Check for the internet status at the top right hand corner of RSP. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
Step 5: If the Internet Status is not connected then, click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next. It will ask for HOST NAME, leave it blank or you can type anything there and click on APPLY CHANGES.
Step 6: Now check for the internet status at the top right hand corner of belkin RSP. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable only for Embarq, century link, Bell Sympatico, Bell Canada ISPs. Because these ISPs will have the IP address same as Belkin routers....
If nothing works then you need to contact your ISP and ask them to bridge the modem...Bridging the modem disables NAT in the modem and allows you to get a public IP in the modem.
click here to configure wireless part...
on May 09, 2010 | Computers & Internet
If you're Bell sympatico is a wireless modem/router and your laptop has built in wireless on it you just need to connect to the wireless signal of the Bell sympatico then that should be the time you can access internet with the laptop, But if your Bell sympatico is only a plain DSL modem you need to get a wireless router that will share the internet to your laptop and desktop so you can roam in your house with your laptop here is a sample of wireless router Linksys WRT54G.
Hope that helps........
Jun 22, 2008 | Computers & Internet
Hook up monitor speakers to PC?
Mar 18, 2009 | Compaq fs740 17" CRT Monitor
Bell Sympatico router connection but no outside connection
check with this tip.
be sure to use same security protocol on your pc as in bell router (WEP/WPA) and of course same Key/Passphrase).
If you don't have access to Bell Router as administrator (and you cannot retrieve it or reset) contact Bell Sympatico.
Jan 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
3com wireless router and Sympatico
well you could probley find a better router that the model you have it is probey a older model and probley will not work on some computers.
Jan 03, 2009 | 3Com OfficeConnect Wireless Router
Belkin router with a laptop
1. First you need to configure your router with your laptop wired or physically connected to it.
2. Connect your modem to router's WAN/Internet port. Then your laptop will be connected to the one of the router's Ethernet port using an RJ45 or Ethernet cable.
3. You may run the setup cd that came with the router. Configure it with the Internet connection type that Bell Sympatico requires.
4. The setup cd will also require you to set up wireless in the router. Once it is done, disconnect your computer from the router.
5. Enable wifi in your laptop and select the wireless network that you set up and connect to it.
Nov 08, 2008 | Computers & Internet
No connection with Inter with dir-625 - connection Poep
If a single computer is connected directly to the speedstream modem(a model number would be an added help), do you need to sign on with your userID and password that was provided to you by Bell Sympatico? if the answer is a yes you may need to setup PPPoE on your router but if your answer is no, then you may need to check the IP address your computer is getting from the modem if it's a private IP(192.168.x.x or 10.10.x.x) that means your speedstream modem is set to PPPoE, check if your router has the similar IP address as your modem, compare the default gateway address your computer is getting when connected directly to the modem and when connected to the router if they have the same segment like 192.168.1.x or 10.0.0.x your required to change the IP address on one of the device, my suggestion is to change it on the router then make sure you connection type is set to obtain IP address automatically(DHCP) or something like that and check if your router will get an IP from the speedstream modem.
Jan 21, 2008 | D-Link DIR-625 (790069292637) Wireless...
2wire modem not broadcasting wireless signal
are the lights on the modem detecting any connection? is your line still programmed for broadband? if your modem is connected at the phone exchange and the connection is at your house and all and none of your computers can connect to the net, not even the primary computer and you have called your technical team for broadband (can be company policy sometimes to call them) you may need a replacement modem. Tech support should do a ping and other tech things to try to get you connected. you may have a faulty modem which if it is new then you should be entitled to a warranty replacement. if it is a simple setting on your computer they should be able to resolve this, i know that when vista first came out there were a lot of support issues with bband providers being able to support the users.
Nov 22, 2007 | 2wire (1000-000057-000) Modem
Computers & Internet Logo
71 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
