Replacing caliper on 2002 dodge neon
The first thing is to make sure the caliper piston is all the way in, the caliper then slides over the brake pads and bolts on, make sure you have the correct caliper on the right side, the way to know this is when caliper is on the little bleeder screw should be on the top, if it is on the bottom then wrong caliper, try the other one,
After caliper is on you will then need to bleed the brake system,
This all depends on what happened, if the brake fluid did not all leak out and caliper was just bad then before removing brake hose off old caliper pinch rubber brake line with a pair of needle nose grips or there is a line crip tool that crips hose to avoid fluid from leaking out. this makes bleeding easier , other wise you will need to make sure fluid is full and start at the right rear wheel bleeding and move to left rear then right frt and last left front, you will need to keep an eye on the level of brake fluid and add as need to keep it from going empty,
you will need some one to pump and hold brake while you bleed them, pump pedal three times and hold down while you open bleeder screw, this is to be done to every wheel about four to five time to make sure all air is out . good day. note if pedal feels low bleed again wont hurt anything just a little more fluid lost.
