Question about Maytag Washing Machines
How do I take the front cover off a Maytag MAV4755AWW washer to change the belt for spinning the drum?
  • Anonymous Mar 27, 2014
    model MAV4755Aww
    Problem Solver:
  • 8 Answers
Although I'm not familiar with that particular model, most Maytag washers have the belts under the washer (no need to remove the front panel) --- just tip the washer back and check to see if the belts are underneath.
Posted on Jun 22, 2008
The inside drum quit turning. is there a belt that turns this and if so how do I get to it. I had the top open but could not see anything. The drum spins if I manually spin it so I know it is not bound up...
if you cant see a belt about 1/4" wide around the drum, there will be a mark where the belt was on the drum before it broke,remove front panel and restring belt around the drum,then replace front drum piece that holds the drum in place and then string belt around idler and motor pulleys and replace front cover
Mar 23, 2011 | Maytag PYE2300AY Electric Dryer
There is a grinding noise during the wash and spin cycles.
hello,
the problem is from the jet strew it indicate that the jet strew need to be reset it at the back of the washer it is connected to the main drum it is commonly call propeller or roller it is the cost of the noise
because it has loss it position connected to the drum
unscrew the washer and see the propeller connected to the drum .
thank you and thanks for using fixya.
Jun 11, 2010 | Maytag MAH2400A Front Load Washer
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
The washing machine belt will move to agitate, but will not move to spin. The spin action burns up the belt. This is an Amana LWA50AW
open rear cover , see if belt slips. then remove belt and rotate empty drum if its jam than drum bearings need to change. if drum is free then belt might be loose and needs replacement.
Nov 05, 2009 | Zanussi FJS1225W Front Load Washer
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Sep 29, 2009 | Maytag Dryers
Maytag front load mah-24. no error codes. humming at any slection but nothing else.drum is not jammed, can manually spin it. won't fill,spin or anything.
Sounds like a belt problem. you can take the back off of this machine to see the belt and the motor. There is 3 screws on the back cover 2 on the rleft as you look at the back of the machine and 1 on the right. remove these to get a look at the belt and motor.
Dan
Aug 10, 2009 | Maytag MAH2400A Front Load Washer
The drum on my maytag epic z washer will not spin. You can hear the motor turning and it going through the cycles, but the drum doesn't spin. Is there a belt off or slipping? What is causing this?
Hi, The belt must have came off. Remove the access panel in the front and see if the belt broke. If the belt is off, see if there is an access panel in the rear that will help you get to the belt easier.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag MAH6700AWW Humming Sound
Can you see water in the drum ?,No water = no action Check water supply
If there is water in the drum does it drain out at some point.
Sequence = Fill, Agitate, Heat, Wash, Drain, Spin etc.
If it fills then it may be a belt has snapped and the drum cannot turn , need to take the covers off to look.
Remove power before taking covers off !!!!
If the belt is OK then it may be the heater which has gone open circuit, try a cold wash or a rinse cycle to test that.
May 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Magtag Performa washing machine
Sounds like you have a timer problem. Insided these timers are small switchs called contacts. These can sometimes get burnt, and wont function properly, especially if one cycle is constantly used for laundry (not your fault, just wear and tear is all). These are somewhat easy to fix, most just have one plug to plug and unplug, and removal of the rear of the dash is all. The timer knob cover just pops off (cap in the middle) then drop timer out. Problem is these timers are not to cheap in price. The timer number for this unit (I believe) is 21001701, and runs about $100. Please, check E-Bay for these parts, they usually are way cheaper and even though they may be used, they still carry the same warranty normally as the new ones, for half the price. Good luck, and let me know if you need further help.
Dec 05, 2006 | Maytag Performa PAV3200
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
522 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
