Question about Maytag MBF2254H Bottom Freezer Refrigerator
Maytag model # mbf2254hew bottom freezer refrigerator
Freezer OK Refrigerator not cooling.
Refrigerator duct device opens and closes OK
However, no cold air comes out of the duct on the inside of the refrigerator.
Fan running inside freezer.
Any ideas?
  • amontes65 May 06, 2009
    upper part is not cold and freezer is cold.
  • Maytag Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorMaytag model # mbf2254hew bottom freezer refrigera - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
What would cause the freeze to be cooling normally and the refrigerator side to be at a temperature of 55 degrees?
all it does is the freezer gets cold,the evap fan blows cold air from the freezer into the fridge section so if the freezer is fine,check the air ducts in the fridge section,if a package or something is blocking the vent on the bottom it will get warm or also on your model you have a damper on the top where the air blow into the fridge section from the freezer,you have an electronic damper,there's a door that opens and closes to let the air in,when it's cold enough the door closes when it gets warm the door opens so either the damper is bad or the computer board that operates it is bad,also check the packages in the freezer,if you see frozen water droplets on the packages or ice on the shelves the door could have been left open and the air ducts freeze so no air can pass through,you can hit the air ducts with a hair dryer to melt them out but be careful,don't keep the heat on one spot for to long,you can damage the ducts,also when you open the freezer door you should hear the fan blowing,if not you could have a bad evap fan motor and the air isn't blowing over to the fridge section,the damper is like 45 dollars and the computer board is around 120 dollars,you can go onto the sears site,put your model number in and look at the controls and you can look up the parts.http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MCD2257HEB/3048/0165000/M0703130/00006?blt=06&prst=&shdMod= copy and paste.open the freezer door,listen for the fan no fan bad motor,if the fan is blowing either the air ducts are frozen or you have a problem with the damper or board that operates the damper,you might want to call in a tech for this if it is the damper,it's a little tricky to do this job but that's up to you.good luck and i hope this helps you out.
Sep 24, 2011 | Maytag MCD2257HE Side by Side Refrigerator
Refrigerator section which is on the top is not cooling, however the lower freezer section is working and making ice. Fan in refrigerator section does not seem to be working. Maytag mod#mbf2254HEW
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. The fan should spin freely when you spin it. You can check the fan plug for voltage to see if it's getting power with the door switch pushed in. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Dec 26, 2010 | Maytag Refrigerators
My refrigerator has stopped cooling - though my freezer is still cooling just fine. Please help!! Model # is Maytag MFD2561KES
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | Maytag MFD2561KES Stainless Steel Bottom...
Refrigerator warming (50 deg) while Freezer Temp OK or Colder than normal
heatman101
Oct 24, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Fridge not cooling freezer top mount ok
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
88dt
Apr 27, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
Help me with me frige not cooling bottom GE unit.
When you close the freezer door, does the fan turn off? There isn't any thing else on my bottom mount beside the damper that regulates airflow to the refrigerator box.
You should be able to drop a string from the damper opening at the back of the refrigerator down to the duct to the freezer. If you can't there is some obstruction in that duct. I suppose it is possible there is some other mechanism in that duct on your particular model, but I can't understand what its purpose would be.
The picture below shows the vents at the back bottom of the refrigerator box that return air to the evaporator in the freezer box to be re-cooled. If these are blocked, the fan can't draw air in to be blown back up to the refrigerator, unless of course the freezer door is open. 7e3c57e.jpg
Jan 09, 2009 | GE Profile PDS22MHR Bottom Freezer...
Refrigerator not cooling but freezer is
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Mar 17, 2008 | Maytag MZD2766GES Side by Side...
Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
Aug 05, 2007 | Maytag MFD2561HEQ 24.8 cu. ft. French Door...
Maytag MBF2254H Bottom Freezer Refrigerator Logo
504 people viewed this question
Top Maytag Refrigerators Experts
isaac johny
isaac johny
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
