Question about HP LaserJet 4L Printer
Laserjet 4L while printing i heard noise and the paper won't feed. i removed the ink cartridge. pressed the cartridge and cover sensor. i can see the paper feeding well. but everytime i put on the cartridge ( new or old) noise appers. has anyone experienced this and what solutions did you do. thanks
  • 138 Answers
What you actually hav is a cracked gear on the main motor. It shows up when you install the cartridge because it requires more torque to drive the cartridge. Remove the top cover, the side formater board. There is 1 screw on the side and 2 on the top that hold in the motor. The motor with the gear attached is available from Dale at Seattle Platen, 1-800-221-2388. Gear only isn't available. Cost is around $25.00.
Posted on Aug 28, 2008
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Jul 12, 2011 | Canon Office Equipment & Supplies
I've got a 4L that has been an absolute workhorse and it makes a grinding noise here recently and will not print. I hate to replace it as the cartridge lasts about 10 years. I know its about 15 years...
The grinding noise is caused by a cracked motor gear. This is a very common issue on the Laserjet 4L and 4P units. It is a fairly easy repair but you will need to disassemble the printer to get to the drive motor. The gear is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
Feb 16, 2011 | HP LaserJet 4 plus Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
My HP LaserJet 4L printer just makes a grinding sound when I attempt to get it to print. It makes the sound for several seconds and then the Paper light starts to flash without printing
Common issue with these older 4L printers. The problem is a small plastic gear on the main drive motor has cracked. This is what causes the noise and since the machine is not "running" there is no paper feed and thus the paper jam light. Basically there is no drive to any of the printers components. May be hard to find a replacement motor these days but that is what you would need to fix the printer.
wheatlandsvcs
Aug 18, 2010 | HP LaserJet 4L Printer
HP LASERJET 4L has a paperjam
1. Open front cover, remove toner cartridge and remove paper
2 Open back door , remove paper
Oct 22, 2009 | HP LaserJet 4L Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Printer says low level color ink fitted new ink printed ok at first but still said low ink order now and will not let me print or scan
Dear customer,
The most common solution is to follow the steps as follows
1. unplug the power cord
2. press and hold down the <ON/OFF> button and reconnect the power cord
3. press the <STOP/RESET> button 2 times and then release the <ON/OFF> button
4. Display LED show "0" press the <+> button 1 time Display LED show "1"
5. press the <Start Color > button 2 times and then press the <ON/OFF> button waitng for testing out 2 pages
6. Open the cover. The carriage that holds the ink will move to the left hand side. and then unplug the power to the printer
7. Push down on the end of the black cartridge. A clicking noise will be heard.
8. Slide the cartridge out of the holder towards you.
9. Push down on the end of the color cartridge. A clicking noise will be heard.
10. Slide the cartridge out of the holder towards you.
11. Once both cartridges are removed, unplug the power to the printer (without turning it off).
12. Reconnect the power cord.
13. Turn on the printer.
14. Open the cover. The carriage that holds the ink will move to the left hand side.
15. Place the black cartridge in the bottom of the printer.
16. Slide the black cartridge back until is cannot go back any further.
17. Push up on the end of the black cartridge, a clicking noise should
be heard.
18. Place the color cartridge in the bottom of the printer.
19 Slide the color cartridge back until is cannot go back any further.
20. Push up on the end of the color cartridge, a clicking noise should
be heard.
hope its udeful. thank you.
Jul 09, 2008 | Office Equipment & Supplies
HP Laser Jet 4L Printer Model #C2003
Try lowering the toner density using the printing software or the printer menu.
Feb 03, 2008 | HP LaserJet 4L Printer
HP LaserJet 4L Printer Logo
91 people viewed this question
Ben Johnson
