Question about Honeywell Heating & Cooling
I have a Honeywell T8000C1002 thermostat I got from my inlaws and it doesn't have the owners manual. I'm trying to hook it up to where an old rocker murcery honeywell was at and can't figure out how to add the power supply. It has a G Rc, W, R, Y, B, O, hook up and I only have the G, W, R, Y from the old honeywell hooked up and can get a display with that but if I try to turn any thing on it loses power. Thanks for any input. Jared
    Scholar:
  • 104 Answers
Your red wire from the old R terminal goes to both the R and Rc terminal on the new stat. Other wires from old stat move to same terminal on new stat. You will not have any connections to the B or O terminal. Sounds like you probably already have it hooked up right though. This thermostat is what we call a power-stealing thermostat. It "steals" is power by running a trickle current to the transformer from the R terminal back through the W terminal. This meathod requires a standard resistive type thermal relay for the heating system. If you have an electronic type circuit board, many times they do not provide the proper type of connection for the thermostat to "steal" the necessary amount of power to run on. This is solved by installing a resistor from W to C in the furnace. If you have a standard electric furnace with thermal relays, then the problem is most likly the thermostat
Posted on Jun 23, 2008
I need to hook up a thermostat honeywell
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can't find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Sep 25, 2010 | Heating & Cooling
I am trying to replace my honeywell T834C2499 with a programmable RTH221. I have hooked the wires as follows: G to G, W to W, Y to Y and R to Rh - leaving the jumper between Rh & rc. My problem is that...
HONEYWELL WEBSITE:
Go to honeywell.com
If you can’t find what you want, the bottom left and bottom of web
May 31, 2010 | Honeywell Programmable Thermostat Heater
I have the honeywelL RTH111 and also had an old thermostat with only two wires...... the manual says to just hook the wires to the same letter slots as it was in the old thermostat..... i did so but the...
Hook up the red wire to Rh (or Rc if they are jumped together) amd the white wire on W.
For thermostat terminal designation
R - 24 V power in
W - 24 V out to heat circuit
Y - 24 V out to cooling circuit
G - Fan relay
Hope this helps
Jan 21, 2010 | Honeywell Programmable Thermostat Heater
Wiring honeywell to old landis thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Jul 08, 2009 | Honeywell Heat/Cool Thermostat
Wiring for a Honeywell RTH2310B
HONEYWELL WEBSITE:
Go to honeywell.com
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Dec 20, 2008 | Honeywell Electronic Programmable...
Cannot get thermostat to work with previous owners programming.
turn the power off to the thermastat for 5 min (should be a switch on unit) and it should reset
Dec 11, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heat pump thermostat replacement
It sounds like your reversing valve energizes the opposite from how you wired it at the thermostat. Check the instructions.
Oct 28, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
397 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
