Question about Radio Communications
Vertex vxr 7000v Repeater Programming help /simplified
GREETINGS I AM A HAM RADIO OPERATOR WITH A NEW VERTEX REPEATER THAT I AM INCORPORATING INTO MY SELF SUPPORTED
CONVERTED AMBULANCE TO ECOMMS AND I HAVE BEEN TRYING FOR 6 MONTHS TO PROGRAM THIS REPEATER TO USE AS A MOBILE ECOMMS REPEATER FOR ONSITE EMERGENCIES. VERTEX GOT GOOD STUFF BUT..... THEY GIVE YOU A 3 1/4 DISKETT TO PROGRAM AND INSTALL AFTER READING THE VARIOUS HAM SITES AND INSTRUCTIONS IT TAKES A 386 COMP TO PROGRAM NOW WITH ALL THE EMERGENCY SERVICE COMMS OUT THERE GOT TO SOMETHING MORE SIMLIFIED I AM COMPUTER LITTERATE AND BUILT A FEW PC BUT THIS HAS STUMPED ME . THANKS TOM .S
  • 3 Answers
SOURCE: Vertex programming problems via USB
This probably doesn't help, but sometimes a much slower (older) computer will work where a faster (newer) will not. The Motorola's are notorious for this. Others, too. USB is USB, a standard--so that's not your issue.
Posted on Apr 20, 2008
SOURCE: GP300 Radios
I recommend you **** can the USB cable and get a RIB and Rib cable. The GP300 Motorola software is available online for free (I can give you the web page address) and works just like the real Motorola software. I have programmed at least 20 GP300s with it with no issues. A RIB is the only way to go. Everyone has nothing but trouble with USB cables. Particularly with newer radios like the CP200.
Posted on Jan 10, 2009
eradiostore
  • 1654 Answers
SOURCE: NEED THE PC PROGRAMING KIT W/ SOFTWARE TO PROGRAM RITRON RPM 450
Contact Ritron at 800-872-1872
Posted on Jul 27, 2009
  • 67 Answers
SOURCE: Trying to convert marine radio to ham band ? Cybernet CTX 1200
big shuift 156 MHz to 144 MHz !!
Posted on Jul 28, 2009
TOLhamRadio
  • 509 Answers
SOURCE: Vertex ftl 1011 programming problem
Hello KC0DED,
Are you using an old computer with DOS ? You cannot use a 'modern' computer, even Windows 2000 will not work. I had to use an old piece of junk and use the serial cable. What software and what computer are you using. You can contact me via QRZ if you want more info.
73's
John, K8DAD
Posted on Aug 24, 2009
I bought a baofeng uv5r and want to link it to my work radio which is a vertex standard vx160u..I can transmit from the work radio to the baofeng but cant figure out how to transmit back to the vertex
First of all, technically, you can't use this radio to talk to anyone other than ham radio- that being said, if you want to proceed at your own risk. Ok, is your work radio an analog radio? Is it narrowband FM? Is it digital MOTOTRBO? Last two will make if difficult. Digital is impossible. Next, find out the exact transmit and receive frequencies for your radio. They may not be both the same if you have a radio 'repeater' your input frequency could be 5MHz higher than your receive frequency. And last- you need to know if your system has a "PL" tone (CTCSS, or DCS) subaudible tone that will break the squelch. So there are several variables that you will need your plant supervisor to relay to you. Good luck. You can probably get much of this info on line from radio reference.
Apr 30, 2017 | Vertex Radio Communications
Channel voice announcement
go into the programming software, settings & see if there is an option, if not it sounds like the radio is on its last leg
or at least try to a factory reset
Apr 23, 2014 | Baofeng BF-888 S UHF 400-470 MHz Portable...
Vertex vxr 7000 flashing display
Sorry I don't have any answers but, my VXR 7000 is flashing SE and I can't get anyone to tell me what is wrong with it.
Apr 03, 2014 | Vertex Radio Communications
Digital tone not bringing up repeater
Without knowing the model of radio or the specific repeater you are trying to access, the only things I can suggest are 1) check to make sure your radio is setup for duplex operation, 2) check to make sure the offset is correct for the repeater, 3) make sure you are in tone mode (not tone squelch mode) and that the tone is correct for the repeater, 4) if the repeater is still not coming up, listen for a while to see if others can access it. If you don't hear other traffic on the repeater there is a possibility that it is down.
Other information that would help get you an answer would be the make / model of the radio (you said Vertex but that could also mean Yaesu), and information on the repeater you are accessing (frequency, location, repeater callsign).
Dec 26, 2013 | Vertex Radio Communications
I need Ce82 for free to program my VX2100, Please Help!!!!!
You also need a cable. It is a business band radio and you should have a shop or tech. Help you so you do not violate FCC Rules. It could be programmed for Ham use depending on the model. Last, you need a current CE82 version because if you get an older CE 82 version than the radio was programmed with last, it cannot be reprogrammed with the old software. Best regards
Oct 14, 2013 | Vertex Cd Vx-2200 Vx-2100 Series...
Low power on vx-3200
No, they are limited to 5 watts and will not go into the Amateur band. Modification of those radios to other uses is illegal.
Jul 02, 2013 | Vertex Radio Communications
What frequencies I can use vertex VX 400 U radio
Not sure what frequencies are allocated in India for UHF ham, but may i direct you to the following: join yahoo group specific to your radio Make/Model, there you can get info and you can download manuals, schematics and other goodies.
I'm sure, but not 100%, that ham bands around the world have similar allocations on 70 cm band UHF, but as I stated, not 100% sure.
Best regards,
Peter
Feb 05, 2013 | Radio Communications
E7 in display
E7 refers to an internal error in your unit.
Please do the following to get expert help:
join yahoo group specific to your radio Make/Model, give the team there as much info regarding your unit as you can, as this will help them find a solution for you, plus you can download manuals, diagrams and other goodies for your unit, and it's all free.
I wish you well and hope I have been helpful.
Best regards,
Peter
Dec 03, 2012 | Vertex Standard VXR-9000 Desktop Repeater
External mic for ft 50 yaesu purchase
Yaesu offers the MH-34B4B Speaker Mic or the MH-37A4B Earphone Mic for the FT50 HT.
Speaker Mic (Heavy / Standard Duty)
Earphone Mic (Light Duty)
Any ham radio store should be able to obtain these - if they are still in production / stock by Yaesu. Ham Radio Outlet aka "HRO" has stores nationwide and can ship direct.
I hope this helps!
Jan 26, 2012 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Vertex manual
try this link
http://www.cqham.ru/sch_eng.html
under yeasu or try foxtrot
Jan 05, 2009 | Radio Communications
Radio Communications Logo
306 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
