Question about Poulan Pro Chain Saw 46cc 20"
How do I change the chain on my Poulan 46cc 20"
  • 528 Answers
Look at the side of your saw where the chain and bar are; you'll see 2 nuts. These nuts will need to be loosened but don't remove just yet. Now look on that same side in front of where those nuts are and you should see a small screw head for a flat blade screwdriver.If it's not there then look on the inside of the bar on the saw body.Loosen that screw 3 turns or so then remove those nuts the rest of the way. Take of the side cover and push the bar towards the saw body - this should make the chain hang off the bar. Remove the chain and pay attention to the direction of the cutting tooth in relation to the lug in front of the tooth. This lug is the anti - kickback lug and on the new chain the lug MUST be in front of the cutting tooth of the chain. Re - install the chain, putting the back of the chain over the drum on the saw first then the front, making sure it is not hung up on the little metal bar on the bottom of the saw. Look on the bar - you'll see a hole in the bar that the peg attached to the screw goes in. Make sure that peg goes into the hole - adjust the peg by turning the screw so the peg lines up properly.Now replace the side cover, holding it flat against the saw body as you re - install those nuts on the saw. Tighten the nuts until they push the side cover flush to the saw. Now lift up on the tip of the bar and turn that screw to tighten the chain and adjust until the chain is flush all along the bar.Don't overtighten the chain as you may fry the bearings.The chain is tight enough when you lift on the chain and you can lift the link you're holding out of the track on the bar, with the bottom of the chain just barely coming out of that track.Tighten the nuts the rest of the way, being careful not to tighten them more than they were in the first place. Now start your saw per standard procedure, warm it up and make 2 cuts. Shut it off and check the chain tension to above specs - and you should be good.
Posted on Nov 22, 2010
  • billybones19 Nov 22, 2010
    Thank you very much for your great information! Bill
  • George Hels
    George Hels Nov 22, 2010
    You're welcome bill. That screw is for adjusting the chain - keep it properly adjusted for loner chain life.Happy cutting!!
2 Suggested Answers
SOURCE:
  • 75 Answers
SOURCE: Poulan chainsaw 46cc 20" chain
You normally have 3 screws - idle speed - slow running and fast running.
First take care as if it runs faster than idle speed that chain will be whipping around also.
Second you have to determine what is the problem. Is it faulty at low speeds or high speeds ? or won't it idle.
If it has turn stops fitted to the screws you only have a small adjustments either way.
If it won't idle, try turning in the idle screw a half turn - until the chain just starts to move slowly.
If its dying at slow speeds, get is going and slow turn the slow screw out until it starts to run a bit rough then turn it back in to the point where its running smoothly.
Bad fast speed can be caused by simple things such as a blocked muffler ( insects too - I had one blocked off by a mudnest wasp) - otherwise get it running at full and adjust the fast screw as per the slow one - out till its rough then back in slowly until its smooth.
Suggest before all this tho that you get it running with the cover off the carby and then give it a good squirt of carby cleaner first - it may just clear out any 'poop' thats there.
(Have faith even tho I have a Poulan with a carb that refuses to run on anything but carby cleaner. I have pulled it apart a few times and renewed all the perishable bits buts its a real pig)
Posted on Feb 28, 2009
How to adjust a poulon pro chain saw 46cc 20" chain tighting
First, I'd read the manual if in doubt. No matter the type of adjuster, tool-less or not, you loosen the bar nuts, tighten the adjuster until the chain just touches the bar on the bottom (while holding the bar nose up) then tighten the bar nuts. Chain should move easily.
Re Poulan chain tightening. Be sure it's oiled and sharp, of course.
Aug 20, 2014 | Poulan Pro Chain Saw 46cc 20"
What is the file size (to sharpen chain) for a Poulan Pro 295 46cc?
I am pretty sure this machine ran a .325 pitch chain, so the file size is 3/16, if it is running 3/8 low profile chain ( 91 ) it will be a 5/32 file, the pitch should be marked on the bar .
Sep 16, 2011 | Poulan Pro Chain Saw 46cc 20"
I would like to see part digram? for poulan PRO 20"
Poulan currently offers 2 46cc 20" bar chain saws which are virtually identical
model PP4620AV, and PP4620AVX
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AV-545014314-952802075.pdf
if you are looking for a different diagram please include the model number you need in the post.
Thanks
Dec 28, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain on my Poulan 20 inch pro will not tighten
If you've got the adjustment all the way out, you may need to remove a link or two from your chain or replace the chain. You can find replacement chains at Partsbuggy.com.
Sep 02, 2010 | Poulan Pro Chain Saw 46cc 20"
Proper spark plug gap for poulan chain saws
I believe the proper spark plug gap for poulan chainsaws is .025-inch. That goes for all units.
Aug 22, 2010 | Poulan Pro Chain Saw 46cc 20"
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
How do i remove or change the clutch on my Poulan model 3314 chainsaw???
Remove cover,chain,& bar. Hold crank and turn clutch counter clockwise to remove.Replace in reverse order.
Mar 06, 2009 | Poulan Pro Chain Saw 46cc 20"
Runs bad like no fuel
well assuming this is your model:
getimage.php?m=pp4620avx&s=s&t=chainsaw
--> poulanpro.jpg&s=hs
Chain Saw PP4620AVX 952802146
  • 46cc 2-Cycle Gas Chain Saw
  • 20" steel bar
  • Anti-Vibe Handle
  • Automatic Chain Oiler
  • Super clean air filter system
  • Tool-less Chain Tightening System
  • 2 Year Warranty
I would go to Poulan Directly and Voice your Complaint with them, they might make it right with You...
You can Contact them at:
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1.800.554.6723
or Via email/request form:
http://www.poulan.com/poulanpro/contactUs.do
Good Luck!
Dec 13, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
191 people viewed this question
Top Poulan Garden Experts
roeb
Jay Finke
Jay Finke
dannydoesita
Are you a Poulan Garden Expert? Answer questions, earn points and help others
