Question about Bosch Washing Machines
Bosch Washing M/C WFL-2050
I had a problem with my washing M/C suddenly making a lot of noise while spinning. Upon opening the back panel, I can see that one of the spring has been broken and the drum has moved to the right hand side, touching the body of the washing M/c. I was wondering if it is necessary to replace both the springs and if there needs to be any alignment to be done before I can use it.
  • bennym13 Jul 05, 2008
    Hi Benimur,
    I have received the original springs and has replaced both of them, the M/C works great. Thanks very much for the useful advice.
    Regards,
    Benny.M
    Brigadier General:
  • 6,966 Answers
Think of the springs as the suspension of a car, their purpose is to provide even spacing/position of the tub/drum relative to the frame/chassis. If you can get an exact duplicate of the spring from the manufacturer, then there would be no need for an alignment. If however the new spring is not identical, then there would be unevenness in the pulling/tension and/or probably even in the position/alignment. Might I suggest replace all of the springs if not an exact part from the manufacturer, this is to assure even pull/tension and hence no need for an alignment.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 22, 2008
Bosch Maxx wfl 1300 washing machine - drum making loud squeaking noise.
sounds like bearing have failed or the stainless steel drum has detached from its carrier open the door and try to move the drum up and down there should be no movement at all if there is machine will need to stripped down
Mar 03, 2014 | Washing Machines
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
What is the life expectancy of Bosch front loader (under counter)? Making loud noises during wash - not spin - cycles. Worth repairing?
not long. have a Bosch Axiss WFL 2060. It started making buzzing noises starting about a year ago and I ignored them. It failed and I am replacing either the motor or/and more things. If ur a DIY its definitely less expensive than a new machine. dwkendall sends
Dec 27, 2010 | Bosch WFK 2401
Bosch wfl 2050/2060 washer door is jammed and will not open
talked with bosch rep-- said there is no manual door release
Jul 25, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer wfl 2050/ 2060 door is locked and will not open
Tom
Unplug it from the power source.
It should release it if not you have a sticky selenoid that locks your system.
If freed. great.. but you need to have that selnoid replaced, because it will happened again.
If the power interruption doesn't work, you need to dismantle your system.
If still under warrenty... Cal a service guy
Washing machine makes a noise (like rocks tumbling) when machine is draining water
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 15, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Grating noise just before spin
This is the noise the trany makes before it dies. It make take some time, but it's days are numbered.
Oct 06, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Flash from the back of the washing machine.
it sounds like the brushes have gone in the motor that turns the drum
Apr 21, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
285 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
