Question about HP Pavilion dv8301nr Notebook
Full system recovery???
Hello, my computer stopped responding (froze) so I did a hard shut down by pressing the power button. When I tried turing it back on I got this message....
We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this.
If your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders, choose 'Last Known Good Configuration' to revert to the most recent settings that worked.
If a previous startup attempt was interrupted due to a power failure or because the Power or Reset button was pressed, or if you aren't sure what caused the problem, choose "Start Windows Normally'.
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Last Known Good Configuration (your most recent settings that worked)
Use the up and down arrow keys to move the highlight to your choice
When I make my choice it brings me right back to this screen. I called HP support desk and he suggested I do a Full system recovery. I don't want to loose all of my pictures and songs and some other files so he told me to get a '2.5" Hard Drive Enclosure' to back up my files first.
Can someone assist me??
  • Corriente Jun 22, 2008
    I don't have access to a CD so the second option is going to be my only choice. And this way it will wipe out my files, but will windows still be there once I'm done with the Full System recovery? I did this years ago and when I didn't have the CD there was no way for me to get windows back on my computer. I guess I'm just worried I'll screw up my computer even more.
    About loosing my files....that is okay if I get the enclosure, but how does that enclosure work? It copies all my files over to another computer? How do I put them back once I'm done with the full system recovery?
    Thank you for your help!!
    Champion:
  • 214 Answers
Hi, don't worry loosing data. it won't.
hope u have the XP install CD.
boot from the install CD and at the screen where the system ask u to select the partition to install windows system, u select a different partition[D or E], not the one where your data are present, may be C:\. complete the installation and see all your data intact.
good luck
Posted on Jun 22, 2008
    President:
  • HP Master
  • 1,314 Answers
If you have access to a windows xp disc, boot it and press R to go into repair mode. Run chkdsk from the command line prompt.
If not, you can press F10 to go into the system recover and, in it's default mode, it will recover just windows files and leave your data in tact. If you go into the advanced screen, that is the full system recovery where you will lose your data.
You can also boot with a live Linux CD like knoppix or linspire and connect a flash drive and copy your stuff over first before a full system recovery.
Or, you can purchase an enclosure or even just an IDE or SATA to USB converter, hook your drive up to it and it to another computer to copy your files over that way before doing a full recovery.
3 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: My computer won't boot.
This would be a good time to recover or roll back what you did, There must have been a change in your configeration.
Posted on Jun 09, 2009
ib_yang
  • 1098 Answers
SOURCE: The screen says "We apologize
If you can go to SAFE MODE, go into Control Panel and go to "System" and then the "Advanced" tab. Click "Settings" under Start up and Recovery. Then uncheck "Automatically Restart".
This will let you see that Blue Screen so you can research the error. Then restart.
The first thing I would do is remove any new hardware that might have been installed, unplug any external devices like printer, scanner, camera, etc... and then try it.
If that doesn't work, pop in your recovery disk. It will help you through the entire process of the repair.
Let me know what happens.
Thank you!
Posted on Jan 19, 2011
Reset tablet
Hello,In order to hard reset your tablet, the steps given below must be followed:
  • Ensure that the tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Power button in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
Hope this helps..
Jan 12, 2014 | Computers & Internet
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
How do I reset the Compaq Presario 1200
Step 1:
which operating system ??
Back up to your external hard drive all of the items on the computer's hard drive that you would like to keep. The hard drive will be completely erased during the recovery process. Open the "Start" menu and then click "Shut Down" to turn off the computer. Allow the computer to completely shut down. Press the power button to turn on the computer and then press the "F11" button when "Press <F11> for recovery" is displayed on the bottom of the screen. Select "Recovery Manager" from the utility screen. Click "Advanced Options" and then select "System recovery." Click "Next" to proceed. Follow the on-screen instructions to complete the recovery process.
Feb 04, 2013 | Computers & Internet
Factory reset on presario cq58
Feb 02, 2013 | Computers & Internet
Factory rest on a presario cq58
Feb 02, 2013 | HP Compaq Presario V2000 Notebook
Keypad not responding upon start up
Hello and thank you for visiting Fixya Support, I will be glad to assist you.
Here is a process I would recommend you try to resolve the issue with your Macbook Pro's keypad not responding.
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac portable.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Shut down the computer.
• Disconnect the MagSafe power adapter from the computer, if it's connected.
• Remove the battery.
• Press and hold the power button for 5 seconds.
• Release the power button.
• Reconnect the battery and MagSafe power adapter.
• Press the power button to turn on the computer.
Let me know if this helps.
Regards,
Mactechtrainer
Mar 07, 2011 | Apple MacBook Pro Notebook
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
Stop 0x000000ED (UNMOUNTABLE_BOOT_VOLUME)
Hmm seen this a few times. This is most commonly caused by your NTFS format layering being corrupted. Meaning that the partition was either not completed when u loaded the operating system or the format has been corrupted from "hard shut downs" This is turning the pc off with the power button instead of going to "start" button and doing a soft shut down. U can try retrieving the format back but u will have programs that no longer responde. Easiest way to solve the issue is reloading your operating system.
Jun 24, 2010 | Dell Inspiron Mini 10 Notebook
SCREEN FROZE TRIED TOREBOOT HARD DRIVE WILL NOT TURN ON
Ok well try actually turning off the computer not using the hardboot button but the wires are connected to a power strip or surge protector right? Well on those there is a switch which you can press and it stops any electricity from flowing into your computer which shuts down your comp. Also many people don't know but when you "turn of your computer" it's really on standby because when you press that button it is waiting for that to be pressed. The only way to fully shut down your computer is to stop all electricity from flowing to the computer. Hope that helped :)
Jan 03, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Windows wx start up failure
The shut down caused a system glitch. You will need to run a system repair with your recovery or operating system disc. Rare, but occasionally, the hard drive crashes under these circumstances and will need to be replaced. Usually if this happens, the hard drive was on it's way out anyway, and would have crashed eventually.
Jul 02, 2008 | Toshiba Satellite A35-S159 Notebook
HP Pavilion dv8301nr Notebook Logo
144 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
