Question about Electronics - Others
Kingston 8Gig mem stick
Y wont a 7G movie transfer from my hard drive to my 8G mem stick?
plz help!
  • Nathan Condon
    Nathan Condon Jun 22, 2008
    your the man home-slice!!!
  • 58 Answers
The FAT32 file system has a limit of 4GB per file. This is normal the file system that flash drives come with. You could format the drive with the NTFS file system to get around this restriction.
Posted on Jun 22, 2008
My usb device not recognized
ok try it different PC.s (simple huh?)
if it's still dead, it is. reformat it.
usually dead mem stickes are caused 99% by removing them
with out first clicking Eject on same. first.
Oct 02, 2013 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Fix my pen drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps
Jul 11, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Loaded my 8G Kingston USB. Next day, properties says zero files, zero free space
Which ever it sounds like it has been exposed to a magnetic field, like a stereo speaker.
Jun 24, 2012 | Kingston Digital DataTraveler 4000 8 GB...
Can not format my flash dti 8g
insert your pen drive
click start right click on my computer select open you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Feb 15, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protect erroe give cant not format and copy files in my 8g DT101 data travel plz help me
write protect error give cannot format and copy files in my 4g DT101 data travel plz help me
Feb 15, 2011 | Kingston Technologies 512MB DataTraveler I...
Hello sir i have kingston 32gb Ccore ccm3110 pendrive it can copy any thing but after copying to my pc the first video file can play ony 14.2 min and others will not open at all solve my problem please
May be your pendrive has corrupted the files or may be your pendrive has some viruses.
I suggest u not to use so much memory on pendrives as sometime pendrive automatically corrupt your data.Use small memory of pendrive.If u want to use big memory it's better u use hard drives
Jan 08, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Cant copy from my laptop to my kingston 8gig flash drive
It may be that your laptop does not support flash drives of that size. Many older PC's/Laptops have firmware drivers that limit to about 2-4 Gig depending on year of manufacture.
Nov 07, 2008 | Kingston flash memory card - 256 MB -...
Kingston mem stick
well i managed to switch it back by re-formatting then reloading the movie, only to find out that ps3's only run FAT32 (4G size files max) so thats why my PS3 won't recognize my mem stick when it's converted to NTFS. so still working on another solution....
Jun 23, 2008 | Computers & Internet
Electronics - Others Logo
60 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
