Gateway gtw-l30m103 lcd tv
WHERE CAN I FIND A POWER SUPPLY MOD #IPL30-L FOR THIS UNIT? HAD THE TV OFF FOR AWHILE AND I WENT TO TURN IT ON AND THERE IS NO POWER. CHECKED THE POWER CHORD BUT THERE IS NO POWER COMING IN
My power board came out of a home theater from Amphion Media Works, now out of business. Looked it up on Google and found it to be a LG power board. Posted note to them earlier today and am seeing loss in many different types of products. So I may be out of luck even this late in the hunt. Guess I'll keep hunting or goto electronics class and fix it myself. :):)
Posted on Sep 06, 2013
  • 6,487 Answers
As I check the power supply specs of this TV the power supply of this is internal that's why its also hard to find this power supply even in gateway web site , so I strongly recommend to you to take this to repair center near you so they can replace the power supply and also to check if that is really the problem.
Good luck........
Posted on Jun 22, 2008
    Genius:
  • 3,422 Answers
HI,
You can get it from www.lcdpayless.com
  • Priya darshan Jun 22, 2008
    Please don't forget to rate or accept the solution.
    Brigadier General:
  • 3,614 Answers
  • micromaster
    micromaster Jun 22, 2008
    you can place order for the parts at this SITE
Hard to turn the tv on
The main power supply regulator board should be checked. This is a very skilled work. It will be best to seek assistance by any experienced service technician.
Oct 30, 2012 | Gateway GTW-P42M303 42 in. Plasma...
Have a vizio vx 42l on the bench. amber light only no power up have my standby 5vdc and my 3.3vdc power button is sending a high pulse to the main mod but i dont get pson to the power supply mod suspect...
This is your mainboard needing replaced! Simple as that!
The main sends the pson signal and without it...you have a dead tv.
Please rate if this helped :)
Mar 10, 2011 | Vizio 42 in. LCD TV
No image just sound
Inspect the power supply board, Z-SUSTAIN board, Y-sustain board for blown fuses, caps, IC, Transistors.
Boards: http://www.shopjimmy.com/catalogsearch/result/?q=Gateway+GTW-P42M303
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 19, 2011 | Gateway GTW-P42M303 42 in. Plasma...
GATEWAY 42" Plasma - tv picture will not come one
Checking the power supply board,that the board,where the power a/c cord plug into it.Could be dying to be dead capacitors parts.Check the power supply board carefully,look for capacitors parts are bulging or puffing up on it tops.U have all the tools and know basic eclectronic also can do basic soldering.Replaced all these dying to be dead capacitors parts,will solved this problems.Or try website like Ebay.com,to buy a whole refurbish power supply board for the replacement.
Dec 09, 2010 | Gateway GTW-P42M303 42 in. Plasma...
I have a gateway 42" plasma television model # gtw-p42m102. When I turn on the main power in the back of the tv, it will turn on, go to a blue screen with an hourglass, then it will turn off and then...
Hi
Its not a power supply issue, but an issue related to the D-board on your TV. There would be swollen/bulged capacitors on this board. To check this you'll need to remove the back panel of the TV. Check the connections to and from the D-board. Make sure the lamp connections are fine and ballast is not burnt. Also check if all cooling fans are working.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 28, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
GTW-L17M103 LCD TV
perhaps a computer repair shop .
Dec 11, 2017 | Gateway LCD17TV 17 in. Television
Lcd will not turn off
same tv similar issue
the menu screen is garbled and the buttons don't work
have to input the numbers on my radioshack remote pushing a 1 then a 3 etc
must unplug cord to reset logic board I was told
great clear picture!! lisa
Apr 29, 2008 | Gateway LCD26TV 26 in. Television
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Electro Med Services...
