Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
STK392-010/ Samsung 47inch
Hello I just replaced both of the STk's and still have the same problem. Can anyone help me figure out what im missing and how to manual set convergence.
Samsung 47inch
Model HC-P4752W
  • bigx99 Sep 30, 2008
    I have the same convergence problem. I would like to remove the stk boards but I'm not sure how to do it. They're attached by pins at the bottom and I'm afraid I'll break them. Could you tell me how you did it. Thanks.
    Problem Solver:
  • 6 Answers
Check the 3.9om fusible resistors next to the stk the small ones with the orange white gold stripes
they are paired so you will have to replace at least 2 maybe more.all the current from the stk goes thru
them.
Posted on Sep 20, 2008
I have a Lawn Boss 6015H the belt that drives the blades snapped so I measured the old one and got a new one. Looked up a diagram of how to route it and put it on but there seems to be lots of slack (too...
You can get a variety of belts in the same length however the width of it varies. Did you measure that? Most belts can be for ei: bought as a 3/8 x 47inch or a 1/2 x 47inch. Very important to fill the pullies correctly with the correct width of the belt. If you have the correct belt it shouldn't give you any grief unless you missed a step in rerouting it.
Oct 19, 2017 | Garden
There are shadows on the picture for my Samsung HLR5667w HDTV.
Hello there,
The television have a problems known as a convergence problems,it is dead.Television have colors R,G,B lines miss alignments,have shadows pictures or 3D picture look alike?Yes the television convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replace on the tv convergence board to solved the television convergence picture problems.
Thanks for using fixya
Caseytech
Jul 01, 2011 | Televison & Video
My TV is showing convergence symptoms: the screen looks like 3D effects and as if someone is pusing in the middle of the screen. I've replaced my STK's, 2 pico fuses on the G board, and tested each...
One of two things:
Either:
a) The STK chips you put in are no good (not uncommon)
or
If you weren't careful you may have removed a surface mount resistor accidently while desoldering the orignal STKs. I had a customer do that to me once and figured it out by comparing the board to the schematic for that board location.
Feb 19, 2011 | Sony KP-57WS500 57" Rear Projection...
Hi, I have a Samsung HCM422W projection Televison and my convergance is not properly adjusting. It will not allow the red to fully adjust. Along with that it seems like the picture is kinda concave. Im...
MOST LIKELY, if convergence will not adjust in some part of the screen and or is bowed looking:
You need to locate the two convergence chips (usually STK-392-020 OR -040 THAT this set should use.
Most of these smaller Samsung sets they are located on a small circuit board mounted above the main boards--see photo of typical chip---should be two side by side.
If they are not located on that separate board, it will be much harder to remove/ replace them.
If the photo or this information helped you rate this solution as very helpful as I do this here for free.
SD TECH
THIS IS A TYPICAL CONVERGENCE CHIP--YOURS WILL HAVE A DIFFERENT NUMBER LIKE STK-392-040 OR -020.
TOTAL PARTS COST ON EBAY WOULD BE UNDER 20 DOLLARS.
Aug 16, 2010 | Samsung HCM422W 42" Rear Projection...
Convergence problem with Samsung Sp47w3hf
You will only need the remote if all goes well.
# NOTE - If this info was helpful to anyone please click on yes!
Jun 22, 2009 | Televison & Video
SAMSUNG HC-P4752W 47
There are three main reasons that convergence can still be inoperable after replacing the convergence amps. One, when the amps failed they blew the fuses protecting the power supply from shorts. Two, when the amps failed the yoke return biasing resistors burned open. And Three the Digital Convergence Unit has failed. Once things have gotten to this point it is usually time to have a professional have a look at the set.
Jun 02, 2009 | Samsung HC-P4752W 47" Rear Projection...
2001 ford taurus p0301 and p0303
You are mis fireing on cyl 1 and 3 if you replaced plugs and wires and coil this is going to be a fuel injector issue or valve issue. See if you can swap the injectors with known good cyl. and see if it changes. Or have a shop do a fuel injector service on it to see if it helps. It may be to late for the fuel injector service.
Mar 01, 2009 | 2001 Ford Taurus
Samsung HLM507W 50 in. STK IC's
STK-392-180s these are the best.Replace BOTH
Feb 01, 2009 | Samsung HLM507W 50" Rear Projection HDTV
Samsung HC-P4241W Convergance problem
press mute 183, if it isn't 183 it's 138.   You will see a large grid which you get the fun of adjusting, it's tedious as all get out! Enjoy!
Aug 27, 2008 | Televison & Video
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
123 people viewed this question
Henry  Thomas
Henry Thomas
