Question about Sony STR-GX700ES
The protector light starts flashing every time I try to use my sony tuner.
  • Anonymous Jul 23, 2008
    my amp will have a loud pop followed by silence and the protector message. turn amp off and then back on... good for an hour or so before loud pop and protector message againg.
My protector light flashes on and off, whats up with the reciever ?
Posted on Sep 16, 2008
Standby light blinks 4 times
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Standby time light on and keeps flashing
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
May 21, 2011 | Sony FD Trinitron KD-36XS955 36" TV
When i try to turn it on i get picture and sound for about 2 seconds and then it shuts off and the red light flashes,
May 07, 2011 | Sony KDS-R50XBR1 50" HDTV
The red light on the front of the TV blinks all the time. No sound or picture. It is a Sony Model KV-21s65
The TV will cause the STANDBY light to blink or flash when the TV detects an issue.
If the TV is plugged into a power strip or a surge protector, please remove it from the power strip or the surge protector and plug it directly into the wall outlet.
If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
Also try connecting the TV to different AC wall outlet and check if that helps.
If the issue persists, the TV needs to be Serviced.
The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired.
Please contact the local Authorized Service Center to get the TV serviced.
Nov 22, 2010 | Sony KV-32S65 32" TV
Screen is blank
Hello
The issue might be that your monitor is not getting enough voltage to turn on properly.
If the monitor is plugged into a surge protector, remove it and plug it directly into the wall outlet. If the monitor works fine, the surge protector is not allowing enough power thru it for the monitor to work correctly - replace the power strip.
If there is no change, then your monitor is going out.
Dec 03, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Protector flashing on Sony AV receiver--Model STR-DG600
Me reicever rite protect some time ,i put the sytem off and a start again
Dec 31, 2008 | Audio Players & Recorders
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
730 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
