Question about Whirlpool Duet GHW9150P Front Load Washer
Stuck lock Cant get the door open....
  • 413 Answers
Unplug the machine. Remove the bottom access panel (three torx screws along the bottom). Reach up under the area where the door lock is and feel for a round door release mechanism. Pull down and the door will unlock.
Posted on Jun 22, 2008
My front loader washing machine won't open-the lock symbol disappears but despite putting the machine through a variety of cycles I can't unlock it
How to open a washing machine door that won't ... - YouTube
? 3:57
Aug 22, 2013 - Uploaded by
Your washing machine door won't open this video will show you a technique ... to our channels social media as this really helpsmy site and keeps us going. ..... Front Load Washer Door Latch Troubleshooting Replacement ...
How to Open a Washing Machine Door that's Stuck Closed ...
? 1:30
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to If your washing ... of thumps on the frontpanel next to the lock to see if this shocks it to release. ....impossible for ariston av51 washer, my arm cant go thru it...small space for ... How to open a washing machine door that won't open normally.
How to open a washing machine door that is stuck shut. > ... > Door Locks & Switches
Jan 04, 2016 | Beko Washing Machines
How do I open rear passenger side door on 2010 santa fe lock actuator stuck in lock position. Can't remove door panel without breaking cant access screws with door closed
Call the dealer ask a mechanic how to open door they likely have a trick and they want you to buy the parts so ask for an exploded view of door and lock you might be able to fish the window and yank the lock bar
Oct 13, 2015 | 2010 Hyundai Santa Fe AWD 4dr V6 Auto...
Why wont my car boot wont open on my citren berlingo ?
Can you give a check to the micro switch that is connected to your boot lock?
If the catch gets stuck, open your drivers door, leave it open,reach across & press down the lock on the passenger front side. The locks will lock/ unlock themselves, because they sense a door is open. Repeat this action until you hear the boot unlock. Also, keep your battery well-charged.
Let us know if this helps!!
Jul 30, 2014 | 2005 Citroen Berlingo
Doors not opening even if they are unlocked
My 2009 Sebring does the same thing occasionally but only the drivers door gets stuck (dead locked - even though the locks appear to pop up).
The solution I have found once this happens is:
1) The car needs to be driven (crawl in thru the passenger door) -even just a short distance
2) Engine shut off & doors locked with remote (after you've exited from the passenger door of course)
3) Leave turned off for 10 minutes
4) Doors will now open when unlocked with the remote
Mar 14, 2014 | 2007 Chrysler Sebring Sedan
My driverside door will not open it is stuck in the lock position
u should be able to remove the cover by the door handle ,the lock rod probably came off the knob for the lock ,if u cant get to it that way then you may have to remove the door panel
Dec 11, 2013 | Chevrolet Lumina Cars & Trucks
Cant open back doors how to open them
It is unusual for both rear doors to have this problem. If they are seldom used they can "stick" however. If you have power door locks and you can see the knob moving when the switch is pressed, chances are the doors are not locked when "unlock" is pressed.
Make sure they are unlocked by pulling up firmly on the lock knob by hand. If that fails, the doors may just be "stuck". Have you tried pulling the inside handle and pushing outward on the door from the inside while a helper lifts the outside handle and pulls outward.
If the doors have "child safety locks" you should only be able to open door from the outside when the safety lock is on.
Aug 18, 2011 | 1997 Buick Park Avenue
The lock on the driver side sliding door was stuck unlocked. Now it stuck locked.
you should clean the locking mecanism and then lubricate with WD40. If this is a van, my van has a sliding power door on the pass side and a manual slider on the drivers. alot of times the drivers locks and dont lock like it has a mind of its own but it always works with the drivers controls. and then the next time i dont think about it and it works. now it also has child proof locks on them, a little plastic lever you slide up and down as to put in a lock position so child cant open from inside and down to allow door to open from inside. double check this. it wont unlock with the key or power? you might have to take off inner door panel to manually unlock this and get it lubed
Jan 14, 2011 | Dodge Grand Caravan Cars & Trucks
Door on 97 Toyota T-100 lock is jammed and cannot open door
My door is also STUCK SHUT, I cant open it from the inside or outside. I understand I need to remove the door panel to fix the issue, but I need the door open to remove the panel. I know I'm not the only person who's went through this. How did you get the door to open? Please let me know how you got your STUCK SHUT door to open so I can remove the panel and fix it. Thank you, desperate T100 owner.
Dec 18, 2010 | Toyota T100 Cars & Trucks
Cant open my boot
That happens quit often on VW, it is the door latch stuck.
Unhook the rear sits, and sneak into the car boot.
Open the door latch from the inside using a screwdriver to move the U-shaped lock, be careful not to damage the lock or the door.
Mar 03, 2009 | 2002 Volkswagen Beetle Turbo S
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De
