Question about Mitsubishi WS-55859 55" Rear Projection Television
Set does not turn on. Green lights continually blink.
After power outage when I tried to turn the set it would not power up. The green lights would not stop blinking.  I hit the reset button and still green lights flash continually.  The set was plugged into a monster brand power conditioner and all other components seem to work and all other TV sets and computers work fine.
Do you offer a repair manual along with tech support and assistance?  I have repaired other electronics by taking apart and cleaning and looking for burned parts, cold solder joints etc but do not have much equipment other than a multi meter and fine soldering irons etc.
  • Mitsubishi Master
  • 8,617 Answers
You need the DM repair kit to rep[lace the bad capacitors on the DM power supply. You can get the V21/V19 DM repair kit at the following link which contains the replacement capacitors and the Cd with detailed instructions for the repair with clear instructions and pictures. heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 03, 2008
MY 32LC7D tv when shut off takes its time to turn back on but now when i tried to turn it back on the green light constantly blinks and no matter if i unplug it the green light automatically comes bac
Televisions now are equipped with a diagnostic circuit that send a low voltage , low frequency signal throughout your set when you turn it on. This is to detect any problems with the circuitry and protect the good circuits.. It started out with a component that wasn't working properly but finally returned the signal. With continued use the component finally burnt out and now your set is going into standby mode. The blinking Green light is a code X amounts = a certain problem. Look up the make and model on the internet and it will give what 2 blinks, three blinks, etc means.. It could be anywhere in the set but the blinks will pin point to the board more than likely. Probably in your power board and if you are lucky it is just capacitors which you can replace yourself if you are a DIY 'er. Check out their web site and find out what your problem is first. Good luck!
Col. Dana Gillespie
Dec 19, 2014 | LG 32LC7D Television
Mitsubishi WD-48511 Flashing green power light
The green light should only blink if set has been unplugged---upon plugging it back it will blink for about 70 seconds and go out----this is the set booting up and is normal.
At that point you should be able to turn the set on-----what happens when you try?
Mar 17, 2012 | Mitsubishi WD Televison & Video
I have a WS-55511 rear projection TV. We had a power outage in the area and the TV will not power at all. Could this be a blown fuse?
if the green power light just blinks that is one issue==========if the green power light does not come on at all suspect a fuse----follow the power cord (set unplugged) into the set and plug in ac fuse is right there.
If you have the blinking light that will not stop it means the DM unit in the set was damaged and that is expensive.
If you need more information or have questions let me know with a comment here.
SD TECH
Sep 17, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have a WD-52525 set that the green light kept blinking after a power outage. The reset button never worked. I unplugged the set for 30 seconds and re-plugged it back in. The light began blinking between...
Bad digital/power module. Contact Mitsubishi, they may cover part of repair, I am serious. If not, have a an authorized servicer send module to Mitsubishi for rebuild program. The only economical solution.
Jan 18, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Green light blinks constantly. reset doesn't fix it.
This set has a lot of problems but I have news for you that I recently discovered from a authorized Mitsubishi repair center---
Mitsubishi has had so many problems with this set that now they sell a complete Chassis replacement for this set for about 200 dollars--You will have to go to a authorized center---no more trying to fix individual boards in this set...if you are in doubt--Google the model number and you will see all the problems this set has had---
Contact Mitsubishi and I think the best thing you can do is get the Chassis replaced--
If you have more questions about what I am telling you let me know---I think Mitsubishi is trying to avoid the class action lawsuits that are in progress against them for this model.
REGARDS, SD TECH
Oct 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
No power just blinking green light
I had this problem last year. Just the blinking green light. the tv would not turn on. It was the power module. A local electronics tech fixed it for me for $300.00. It was a circuit in the panel that needed to be changed.
Aug 29, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Green Power light keeps blinking and set won't turn on
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Feb 06, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
