Question about Kitchen Ranges
Oven on our electric kitchenaid stops working and f2e1 error message comes on. It does this frequently
  • 3 Answers
UNLOCK DOES NOT RESPONT AND ERROR F2E1 COME ON
Posted on Aug 09, 2009
  • 413 Answers
F2E1 is a fault code that indicates the keypad my be unplugged or has failed.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Posted on Jun 22, 2008
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
F2 E1 error shows on display. KitchenAid model KESC308LSSO Electric range. Oven stops working after 90 minutes at 350 Def. F. Starts working again after cool down.
On your model the "F2E1" error is for a faulty control board and it will need to be replaced. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 24, 2012 | Kitchen Ranges
Kitchenaid superba f2e1. I have no idea what happened. I was cooking and then this code came up nothing works now. any suggestions?
Hi
F2-E1 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | KitchenAid KESC307 Electric Kitchen Range
Err F2E1 stuck/shorted key
The control panel is either faulty and needs to be replaced. One can be purchased at repairclinic website or partselect.
Or you can dismantle it, and clean everything with rubbing alcohol and a cotton swab
Apr 27, 2010 | Ovens
F2E1 message on range
I have a repairman coming to check it out.
Jan 25, 2010 | Kitchen Ranges
F2e1 error message
It is the only ribon cable coming off of the control panel to the control board. This error could also indicate that the control panel is bad.
Apr 12, 2009 | KitchenAid KEBC107 Electric Single Oven
Error Code F2E1
Did you try unplugging it for a couple of minutes and replugging it?
This might reset the computer control.
Jan 17, 2009 | KitchenAid KGRS807SSS Gas Kitchen Range
Oven not working
F2E1 refers to disconnected keypad.If you can; check for the keypad, else have it replaced.
Jan 01, 2009 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
759 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
