Question about Frigidaire Kitchen Ranges
Frigidaire gas range - model plcf489ccc - the ignignitor continues to spark and click even when everything is turned off. We turned the power off for a while and when the power was turned back on it continued to click and spark.
  • asteele407 Jun 24, 2008
    this helped my husband some - but a bit more explanation would have been helpful
  • 413 Answers
Mounted on each each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. On some models these switches are individually replaceable, others the switch is an assembly of all four.
Posted on Jun 22, 2008
Igniters always on with a fridgedaire duel fuel range?
You should have a professional diagnose this. This unit should not have any clicking or ignitors on while not in use.
Dec 28, 2012 | Frigidaire FPGS3085KF Stainless Steel Gas...
Cleaned the range, now all four pilots are continuously sparking it will lite when gas is turned on, but continues to spark
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Feb 17, 2011 | Maytag Gemini 30" Self-Cleaning...
Gas oven doesnt work
Hello there:
Gas oven won't work, Ignitor is glowing Everything in the circuit must have continuity for the oven to fire up. What if the ignitor glows but the oven will still not come on? If the ignitor is glowing that would mean you have a circuit. Solution: Replace the ignitor, even if it comes on. Why? Because 99% of the time the ignitor is weak. When it is working fine it should be so bright you cannot look at it for long. If it is a mellow orange color it is bad, replace it. The only way the gas oven valve would be bad is if it is open and has no continuity. That goes for the control as well. Check out this simple diagram of how a basic gas range operates. glowbar.jpg oven ignitor An ignitor must draw at least 3.5 amps or that safety valve will not open up and release the gas: gas-ignitor-circuit.anim.5. Click on image to see it in motion
Apr 27, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignitors won't stop clicking
there is dirt between the ignitor and the burner or the ignitor is to close to the burner
Feb 15, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
87 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
