Question about Lasko 48" Xtra Air Tower Fan with Air Ionizer
Cleaning Trying to take apart my Lasko E20739 fan to clean it. Is there a diagram available?
  • 1 more comment
  • Anonymous Jul 09, 2008
    how to clean lasko fan
  • jeremyinutah Jan 02, 2009
    Most 'ionic air purifiers" I know of are cleanable. If this does anything, I assume it gets dirty. How do I clean it?
  • adajane690
    adajane690 Jul 15, 2012
    There were probably a dozen screws to remove before the back could be opened. I removed each one, cleaned the blades well with my vacuum sweeper, closed the back up and plugged in it. Turned it on-no movement. Set it out for the trashman and I'm going to the store for a new fan.
Model E20739: The entire back comes off to expose the fan blades after removing two screws. Just unplug the unit. On the back of the unit near the top is a recess that acts as a carrying handle. In that area you will see two large silver-colored screws. Remove these, grasp the back of the unit and push down on it as you pull it away from the body of the fan. You may have to wiggle it around a little to free it.
Posted on Sep 03, 2010
The E20739 is Lasko model 2543 , link to the manual
http://www.laskoproducts.com/usermanuals/2534ExecutiveTowerFan.pdf
Posted on Apr 19, 2013
HECK IF THE DARN THANG STOPPED WORKING AFTER YOU CLEANED IT AND PUT IT BACK TOGETHER ...I WOULD JUST GO AHEAD AND BUY A BRAND SPANKIN NEW. I REALLY LIKE THE UNIT . BUT I FEEL IT NEEDS AN EASIER ACCESSIBLE WAY TO GET TO THE INSIDE AND CLEAN :) JUST SAYIN PEACE GOOD FOLKS
Posted on Jun 25, 2012
What need's to be done. Well what i done was took the fan apart and clean the fan everything, clean out all the dust fan cone.All that good stuff, Then after that put back the way it was plug in now your fan will work. That's for when the fan power on, and rotate but the fan cone don't turn on its own power,It just need's to be clean out just like any fan....It's now broke !!!!!!!
Posted on Jan 11, 2011
  • Maxsmoothred May 21, 2011
    I don't speak hillbilly. What are you trying to say here Billy Bob?
How do i take apart my lasko cyclone fan to clean the inside of it
You may need to UNSCREW the front half of you fan guard plastic casing or depress it in a few place if you see notches on the cage itself. Remember the knobs you will be removing to take the blades off to clean will be threaded opposite, one will screw off and on clockwise then other counter clockwise. Be sure FAN is UNPLUGGED BEFORE YOU open it up. Lay all parts in bathtub, Spray with Cleaning foam, pour lots of water over to clean all sides, then let drain and dry in bathtub. Less muss and fess this way!
Aug 09, 2014 | Lasko 3510 cyclon Floor / Box Fan
Lasko blower fantype DTB E20739 PM7331
to clean your fan from dust
Jul 02, 2013 | Air Purifiers
Can I take my fan apart to clean it?
YES ! I have several fans and I have taken them all apart. They are easy and fast to take care of. Only a few screws and some light cleaning and simple oiling and she will run like new. I do mine atleast once a year... post how you do... Tim
Sep 14, 2012 | Lasko Dryers
How can I fix my Lasko E20739 tower fan, when the motor stops running?
That fan has an electronic (computerized) control board which sometimes malfunctions. Nothing new there, right?
The problem is that the cost of the repair can excede the price of a brand new replacement, with a warranty to boot.
You may take it to a service depot and get it checked out, provided you get an estimate and this is done free of charge.
May 25, 2011 | Vacuums
My Lasko E20739 blower fan works but does not oscillate. The small 120V motor that does the oscillating seems to be the problem.Please confirm and advise where can I buy s replacement motor Peter
i don't think it's going to be a motor issue, these fans have a round plastic gear in them that commonly go bad. remove the bottom cover by removing (5) phillips head screws, then unwind the power cord from the cord holder rembering the path, then remove the (3) large phillips screws, then just slide the base of the fan off and the gear is right there. if the gear is bad, you'll know cause there'll be pieces of plastic everywhere and the teeth on the gear will be rounded off. have fun. oh, for the part, i suggest contacting lasko at www.laskoproducts.com
Aug 21, 2010 | Lasko Heating & Cooling
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
How do I clean/take apart the Lasco tower fan, mine is working but extreamly dirty. Purchased 3 at WalMart and ; no paper work in boxes.
Easiest solution is going to be compressed air, not canned air for blowing out keyboards and computers, but compressed air from an air compressor. These fans are not designed to come apart for cleaning.. they're meant to be used a year, thrown away and you buy another one.
Mar 31, 2010 | Lasko 2530 Elite WindTower Fan
Cleaning my 2554
there are 20 screws to take apart the fan.
but try this
something to wedge the blade and blow out the fan. it will work jus the same
Jun 28, 2009 | Lasko 2554 WIND CURVE Fan
Lasko E20739 Fan
I would love to tell you yes, but I ended up buying new fan.
The common wire was broken, buried in the windings and no way to repair without
damaging the windings.
Could not find anything on line.
Sorry,
mrboo747
aka Gary C
Nov 10, 2008 | Lasko 2530 Elite WindTower Fan
Lasko E20739 Fan
It sounds like the electronic controls have put the fan into "breeze mode". The fan turns slowly then is supposed to surge back to high. Some people love this feature for some reason...
Disable breeze mode via your remote (its the button with the stacked ~'s).
A bad motor wouldn't rotate at all. The only other problem might be the motor's running capacitor. If you can start the fan in either direction (give it a hand spin in the opposite direction of rotation) you have a bad capacitor...and you can find a replacement anywhere (Radio Shack).
Aug 03, 2008 | Lasko 2530 Elite WindTower Fan
Lasko 48" Xtra Air Tower Fan with Air Ionizer Logo
2,553 people viewed this question
Top Lasko Dryers Experts
Tommy Thomas
Tommy Thomas
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
