Question about Haier HVT12ABS Compact Wine Cooler
WINE COOLER WHERE MIGHT THEY BE LOCATED I AM A ROOKIE I DO HAVE THE BACK COVER OFF ALL HELP IS APPRECIATED THANKS I HAVE THE HVT18DFBB MODEL
  • 750 Answers
Hello jelani372,
Happy you assist you.
You asked,
I believe this is the web site you asked for!
http://www.haieramerica.com/en/
Bless You,
Please rate me as solved, before you sign off please. Thank You!
Posted on Sep 14, 2008
Aficionado hvt18dfbb is running but NO TEMP CHANGE
There is no compressor on these units. These units use a Peltier cold/hot module where the cold side faces the heat sink and the fan exhausts the heat side. Another fan sends the cool side into the frig. I have the same unit, I am experiencing the same issue. I was looking to change out the Peltier modules (about $7 each) and try that. I did find a replacement Control Board is about $45 and if the Peltier change doesn't work this may be my next step.
Nov 08, 2012 | Haier HVA052ALL-8S 52 Bottle Aficionado...
Can't figure out how to change the light bulb in my Wine Cooler? Can't get the plastic cover off? help!
Hello there,
How many techies does it take to change a light bulb (without a hammer)?
There is a tiny screw holding the lens cover in place. Once removed, the lens will come off and you can access the bulb.
Hope this helped
Thanks for using FixYa
Mike
Jul 24, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
I need to know where the board RF-5210-56 is located on the wine cooler model hvts18DABB
Number 19 in this photo is the control boards location=> HVTS18DABB Parts Breakdown
and if you need the user manual click here=> HVTS18DABB User Manual Please rate this if helpful and should you have more questions please ask, Thanks Sea Breeze
May 09, 2011 | Haier HVF042 Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Oct 29, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
My GE Profile wine cooler temp does not respond to any temps
Call GE answer center 1-800-626-2000 ask for tech help,have Model # off data plate ready.
May 09, 2009 | GE PWR04FANBS Wine Cooler
Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
May 03, 2009 | Haier HVFM20ABB Wine Cooler
Need user manual for Emerson Wine Cooler FR23RD
HI. i couldn't find the FR23RD but, i have been told that this manual covers your model. It basically covers FR24SL threw FR24RD. Your model is also covered in this edition. Click to review your manual.
Please rate and god bless.
Mar 22, 2009 | Emerson Refrigerators
Danby wine cooler model dwc172bl thermostat replacement
Once I figured out there were black plastic caps covering the screws holding the inside back panel in place, it was an easy fix. The cooler is now up and running. Thank you for giving me the $10 incentive to figure it out myself.
Jan 18, 2009 | Danby Silhouette DWC512BL Wine Cooler
Haier HVT12ABS Compact Wine Cooler Logo
283 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
