Question about Janome Memory Craft 9000 Computerized Sewing Machine
Janome 9000 could not sew straight stitch!
Hi, I was in the middle of sewing a garment using straight stitch, suddenly the needle shifted to the right as if it tried to sew zig zag... I stopped immediately as I knew the needle would break. I tried changing needles, re-thread, cleaned underneath the throat plate, nothing looks amiss, but the same thing happened again & again, I couldn't get pass the second stitch... What is wrong? I also switched off & re-stated the machine several times.
  • 749 Answers
SOURCE: upside down stitching
try adjusting the thread tension control! a loose setting would cause the problem! try increasing tits tightness!
Posted on Nov 02, 2007
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
  • 26 Answers
SOURCE: needle jaming and thread gathering under bobin case
when this happens to me (the needle breaking) I make it a thing to do and that is to use a qtip with a bit of oil and clean the bobbin holder and then use canned air and blow out the lint from area and this may help you. You may have a tiny tiny piece of needle left in the holder and this will play havoc with any kind of sewing machine. I have suffered through it many times before I made this a practice when needle breaks
Posted on Mar 08, 2009
  • 111 Answers
SOURCE: When sewing the bobin thread tangles and jams
upper tension/threading wrong?
Posted on Jul 08, 2009
  • 46 Answers
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Posted on Jul 27, 2009
How do I do a Pin Stitch with a wing needle on my Janome 12000?
I believe you pretty much use a wing needle like you would a regular needle. These links may be helpful:
What is winged needle
How To Sew Hemstitch Using Wing Needle
Tips on Using Wing Needle
Be sure to practice on scrap fabric before using it on your garment.
Oct 05, 2016 | Janome Sewing Machines
Having a problem with stitch tension can you help
is it just the fabric that is gathering or the bobbin thread also ?
Jan 24, 2015 | Janome Memory Craft 9000 Computerized...
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
My machine is skipping stitches i have dusted it, rethreaded it, changed the needle and still it skips
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 17, 2012 | Janome Memory Craft 9000 Computerized...
What is the janome equivalent of kenmore 19100600
try these sites for the part--you may have to email them about the part
May 03, 2012 | Janome Memory Craft 9000 Computerized...
Lower the pressure on the feed dogs, use a stretch stitch, and longer stitch length. Be sure to use a good quality thread, and maybe go lighter weight thread.
Oct 25, 2017 | Janome Memory Craft 9000 Computerized...
Janome SD 2014 problem with straight stitch
I have the same problem with the same machine. Can you tell me if you got it fixed, if so how?
Dec 23, 2008 | Sewing Machines
Loose stitches every 1
test it out on 2 pieces of material by rotating the wheele by hand. pay close attention to the 1" area. when you turn it by hand you can feel the area of question. is your bobbin spooled correctly. if all fails read the directions.
Jan 16, 2008 | Janome Memory Craft 9000 Computerized...
Touch screen not responding
Hi, my dealer told me mine might be going and it would cost $500 to repair it and it would have to be sent back to Janome for the repair.
He said when it goes, it will be stuck on the last stitch you used.  You can still probably keep it for a straight stitch machine if you did not want to send it for repair.
Jan 06, 2008 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
78 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
