Question about Arris Touchstone 450a (CM450) Modem
Connecting my arris modem to x-box live
Hey im tring to connect to x-box live and the rep. from x-box told me they have problems with arris modems can you help?
  • 31 Answers
I have an Arris cable modem and use Xbox live. They work very well together. Most ISP's will only allow one active device at a time. When you switch between you cable modem and your Xbox you need to use a pen and press the reset button on the arris every single time you switch.
Posted on Apr 09, 2009
I have an Arris modem from Comcast that gives me phone and internet service. Prior to going to Comcast for telephony I used a regular, off the shelf, modem and I could connect to my Direct TV sat box via...
comcast use 10.0.0.1 for ip address, I think
check direct tv box for internet settings for it's ip address should 10.0.0.2 maybe call directv maybe they could further.
May 14, 2017 | Arris Touchstone 450a (CM450) Modem
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
I have my main computer set yp with arris router
  • You can use both Ethernet and USB interface to connect two PCs simultaneously with one cable modem.
  • If you plan to go wireless (and maybe connect more computers), you have to purchase a router to split/share the internet connection coming from the modem.
Apr 07, 2010 | Arris Touchstone 450a (CM450) Modem
I HAVE SUDDENLINK AND IM TRYING TO GET CONNECT TO XBOX 360 LIVE
Well you need a modem to connect you're console to the internet. call you're company and set up your modem, sometimes you can actually get a modem from your company directly. then you plug your x box into the modem and let them establish connection for a minute( just let them sit, it should be automatic) then go to test x box live connection on your xbox, it should be in settings and then network.
Feb 21, 2009 | Microsoft Xbox 360 Console
I have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
Feb 15, 2009 | Arris Touchstone 450a (CM450) Modem
Connect internet via ethernet
to use dhcp with several computers, you need to have a box that allows the dhcp mode and which is configure to goes on
Jan 17, 2009 | Apple Power Mac G5 Desktop
Linksys router and modem problems
Most cable company's will not allow you to use the USB and the ethernet connection at the same time. You will need to only use ethernet to your PC and your XBOX. Once you have the ethernet cord connected from your modem to the WAN/Internet port on your router you will need to press the reset button on the back of the arris to authorise the router for access. After that is done you will plug you XBOX into 1 of the 4 numbered ports on the router. Then you will need an additional ethernet cord for your PC.
Hope this helps
Jan 04, 2009 | Arris SURFboard SB5120 Modem
How is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
Jul 22, 2008 | Arris Touchstone 450a (CM450) Modem
Arris Touchstone 450a (CM450) Modem Logo
959 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
