Question about Sony PlayStation 2 (PS2) Console
My Ps2 slot for memory card saver wont work. The second slot works fine, but the first slot you cant put the memory car in. If you can hel Best regards.
    Problem Solver:
  • 16 Answers
Try cleaning the slot with the use of a flattened q-tip dipped in an alcohol and check if there's something blocking the memocard from being inserted
Posted on Jun 23, 2008
Why is my ps2 memory card reading no memory when theres only five games on it? And its a 64 MB memory card which was working fine before. Should I whip it? And if so how?
HI, Please remove and re fit your card on its slot. If problem persist, your card is broken. I don know why memory card for ps2 is very bad. Regards
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
I have no manual my problem is I have a First Generaiton Ps3 and would like to transfer my Ps2 memory card and cant figure it out. pleae help thank you Nichole
Prerequisites There is no PS2 memory card slot in the PS3 so will need a Memory Card Adaptor. Sony made an official adapter but there are also a number of cheaper alternatives. Buy one online:
Steps
  1. Plug your PS2 memory card into the adaptor
  2. Plug the adaptor into a free USB port on your PS3
  3. Go to the "Game" menu in the XMB and choose "Memory Card Utility (PS/PS2)"
  4. If the adaptor is working you should see an item called "Memory Card (PS2)". Below the title should be the size of the card and how much is in use-in my case "1334 KB / 7998 KB"
  5. Press the controller's Triange button to get the Memory Card options. Select "Copy"
  6. Select "Yes" to confirm the copy from memory card to the hard drive
  7. Enter a name for the new Internal Memory Card that will be created on the hard drive, or leave the default name. I named mine "Original PS2 saves". Select "OK"
  8. The data will be copied. If the amount of saved data is too large, the system will automatically create multiple internal memory cards
  9. You may be informed that the new internal card has been assigned to a "slot". These slots are an emulation of the physical memory card slots in the PS2, so similarly you may only have two internal/virtual cards "plugged in" (assigned) at a time. The internal memory card must be assigned to slot 1 or 2 to be available when you run PS2 games
  10. The new internal memory card should now be showing in the XMB, under Game > Memory Card Utility
  11. Selecting the card will allow you to browse the game saves that were copied across!
Jan 04, 2011 | Video Game Consoles & Games
My memory card slot 1(PS2) does not read cards but slot 2 does?
take out slot one memory card and insert your second memory card into it (they are supposed to use slot 1)
Dec 23, 2009 | Sony PlayStation 2 (PS2) Console
New ps1 mem card wont formaton ps2...
I have read that some manufacture PS1 memory cards will not work properly on the PS2. I would suggest trying another PS2 to see if it's a problem with your specific PS2. If the memory card doesn't pop up on the browser screen of another PS2, it could be defective or incompatible. If it does work on another PS2, it could be something weird going on with your memory card slot on your PS2.
Oct 09, 2009 | Sony PlayStation 2 (PS2) Console
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
I bought a second hand ps2 games console from a shop known as cash generators. It was a while ago now. I later tried one of the view games that i have, shortly after realising that i didn`t buy a...
Cash generators are rubbish! I buy a lot of things from there, and it's very hit and miss. Even with a receipt they dont always agree to give you a refund!! Grr!!
Anyway. Can you quickly try the following:
-breathe into the memory card - make sure the moisture from your breath gets onto the contacts.
It a bit like spraying WD40 on a car when it wont start. Sometimes its all it takes.
If that doesnt work then given that the card works in another console, I'm afraid in all likelihood you've been sold a faulty PS2. Sorry :(
Nov 04, 2008 | Video Game Consoles & Games
New PS1 memory card (OEM) won't work in slim PS2
PS1 memory card do not work with the PS2.You have to buy PS2 memory card to save for PS1/PS2 games using PS2 game consloe.
Oct 09, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Memory card problem
there is an eternal problem get a NEW ps2
Aug 30, 2008 | Sony PlayStation 2 (PS2) Console
Final Fantasy 8 cant load my ps2 memory card while playing on ps2
yes you would need a ps1 memory card to load ps1 game files on ps2
May 12, 2008 | Sony PlayStation® 2 Console
Ps2 memory card
Hi Lofatman,
If this problem happens with the memory card when its in either slot 1 or slot 2
I suggest you clean the contacts of the memory card.
If it just happens when you have in Slot 1 or Slot 2 only,
 Go to Radio Shack and get a Can of contact cleaner that has a Brush built into the Spray nozzle.
  1. Turn off the PS2 and disconnect the power cord.
  2. Use a small screwdriver to press open the memory card slot. Do not use too much force, its delicate.
  3. Push the Brush sprayer up into the memorycard slot and spray a little and brush away at the memory slot contacts.
if you do not have success with that, you must open the PS2 case, and Remove the Controler ports and clean up the whole controller port assembly.
If that doesn't work, and your frustrated and not Electronically skilled enough to do this.  I can get the PS2 in tip top shape, for $32 and that includes return shipping.  I run the website www.playstationclinic.com
This should put you in business.
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
67 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
