Question about Olympus Cameras
I have a C-2100.Troubleshoot says card full. Can't get display to change to clear card or any other functions.
Lightly jarred the camera loose connection on sd card.
Posted on Jun 22, 2008
WHAT IS THE MEANING OF CODE D16?
(D16) Gen 2 Card Reader Communication Fault This fault occurs when the control has not received a health check function from the Gen 2 debit card reader in 30-seconds. If this fault occurs in Ready or Vending Modes, the control will log the fault and display "OUT OF ORDER". Once the control enters READY Mode and the fault has not been corrected or cleared, the control will display "OUT OF ORDER". The fault is self clearing; therefore, once communication is reestablished, the control will clear the OUT OF ORDER condition and allow full dryer functionality again.
Dec 20, 2015 | Maytag MDG16PD Gas Commercial Dryer
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
How do you clear memory??
you probably need to clear the history as it is probably full
Apr 16, 2014 | KDS Computers & Internet
Please give me everything information about LG GW 525
The new LG-GW525 is a Slider QWERTY Touchscreen Phone with enhanced messaging and social-networking capabilities.It is a 2.8-inch full touchscreen phone featuring a 3-megapixel camera.There is no WiFi in it. The main features of the new LG-GW525 Slider QWERTY Touchscreen mobile phone are:
  • RF Band: GSM 850/900/1800/1900,UMTS 900/2100
  • Display: 2.8-inch full touchscreen TFT display with 240×400 pixels resolution
  • Dimensions: 106.5x53x15.9 mm
  • Slim and Compact design
  • Slider QWERTY keyboard
  • Enhanced messaging and social networking features
  • Push e-mail and instant messaging
  • 3 megapixel camera
The detailed specifications of the new LG-GW525 mobile phone are:
  • Network:GSM 850 / 900 / 1800 / 1900,HSDPA 900 / 2100
  • Dimensions:106.5 x 53 x 15.9 mm
  • Weight:125.5 g
  • Display:2.8 inches TFT resistive touchscreen, 256K colors,240 x 400 pixels
  • Full QWERTY keyboard
  • Accelerometer sensor for auto-rotate
  • Memory
  • Internal:40 MB
  • Card slot:microSD (TransFlash), up to 16GB
  • Data
  • 3G HSDPA 7.2 Mbps
  • Bluetooth v2.0 with A2DP
  • USB v2.0 microUSB
  • Camera:3.15 MP, 2048×1536 pixels
  • Stereo FM radio
  • Colors:Blue on Black, Red on Black, Silver, Pearl White
  • MP3/MP4/AAC/AAC+/EAAC+/WMA player
  • MP4 player
  • Document viewer (DOC, XLS, PPT, PDF)
  • Battery:Standard battery, Li-Ion 950 mAh
  • Stand-by:Up to 500 h
  • Talk time:Up to 5 h
Mar 29, 2011 | LG GW525 Cell Phone
How to change the time
You can find the full manual here:
http://www.obfs.uillinois.edu/common/pages/DisplayFile.aspx?itemId=918000
But here's the part about changing the time:
System Reset-DATE or TIME
To change the terminal Date and/or Time:
1. Press the More function key.
2. Press the green Enter button until the terminal screen displays Other Set Up.
3. Enter the password (last six digits of the Merchant ID# or 998877).
4. Press the Enter button.
5. Press the More function key.
6. Press Enter until the terminal screen displays Date/Time.
7. Press Enter for Date (MMDDYYYY), enter the correct Date, and press Enter. Go directly to Time, and bypass Date, by pressing Enter twice.
8. Press Enter for Time (HHMMSS), enter the correct Time, and press Enter.
9. To Exit, select the red Cancel/Clear button twice.
Mar 20, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Imagistics SX 2100. When you change the drum what
Open the door where the toner cartridge is, and push the clear key and look at the display where it will say reset no press 1 yes press 2. That should do it.
Jan 25, 2010 | Pitney Bowes Office Equipment & Supplies
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Aug 30, 2009 | HP LaserJet 3015 All-In-One Printer
New SanDisk 4GB CF Card - Coolpix displays out of memory
This is because the Coolpix 2100 and 31000 models cannot handle a card of that large a capacity. As it's only a 2MP camera anyway it doesn't need it.
The Coolpix 2100/3100 will usually accept up to a 512MB CF card, and 1GB Lexar CF cards up to and including the 24x WA write accelerated (although write acceleration itself offers no benefits on this camera). With Sandisk only a plain old and now obsolete SDFB allows a 1GB card to be used and the regular Sandisk Ultra (not Ultra II or later) will only work up to 512MB.
The camera was discontinued long before these much larger CF cards were released and Nikon no longer actively support the product so no firmware updates will be available. The hardware wouldn't support such cards anyway.
Compatibility chart for CF cards address below:-
http://nikoneurope-en.custhelp.com/app/answers/detail/a_id/26030/c/241/r_id/127673
Jun 17, 2009 | Nikon Coolpix 2100 Digital Camera
2100 - Date function not working after 31st may 2009
ITS THE SOFTWARE FAULT U CAN GET THE SOFTWARE REINSTALLED IT WIL DO THE WORK
Jun 10, 2009 | Nokia 2100 Cellular Phone
Cameras Logo
19 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
