Question about Brother MFC 1950MC Printer
Print only on rigth side. I know it the blue lever. Where can I get parts
I have the same problem with my 1950MC. When I examined the blue lever carefully on the right side of the machine I found that the plastic lever was cracked at its thinnest point. Thus when both levers are locked down that one was not holding the print head tightly enough to print that side of the paper. If I held the print head down manually, the copy printed fine. So if you have this problem, check the blue levers for cracks. The levers are easy to remove and should not cost very much. I recommend that you replace both left and right levers. These plastic parts cannot stand up to very much use without cracking.
Posted on Jan 16, 2009
Samsung clx-3180 printer is showing printer offline and will not print from pc.
CHECK
Printer is connected and power ON
In panel contro
go to Printers
choose Samsung Clx rigth click
unmark the check Use printer offline
Try printing a test page
rigth click Properties
click on
Print test page
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
There's a lining in rigth side of my LCD. How do i
Sadly you will have to replace the LCD. Going to a trusted Acer Dealer (preferably the one you bought the laptop from) will help you get the best price on the LCD.
Jul 26, 2011 | Acer Aspire One 10.1" Netbook Computer -...
We print a 3 part Invoice and the print on page 2 & 3 are so light you can hardly read them.
On the left side of the ribbon holder is a blue lever. move this towards the paper (rear of the printer) until you get clear prints
Dec 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Zm400 print a part of a label. Hello, my Zebra ZM400 only print 1/5 last part ot the barcode label. Could you please tell me how to fix it?
What part, rigth site or bottom site?
check the lengt and the with from the driver and print the testpage (have to print on full label)
if is one of the sides, try to give more pressure to that side on the printhead.
Nov 17, 2010 | Zebra 203DPI Printer
Only half of incoming faxes are printed.
Is this a machine that uses a big, black roll of thermal donor film? The Fax 1250 and several other models have a common problem where the left side prints perfectly, but fades to blank on the right (or the opposite). When you replace that donor film cartridge, you open the top and push a blue lever back on each side to raise the print element assembly.If one of those levers cracks, it will still hold down the head and look normal, but it won't hold it tightly enough the paper to to print on that side.
For models Fax-1150/1250M/1350M/1450MC/1550MC
the parts are
Left (as viewed from the front):UF6085001
Right: UF6087001
One or two screws hold the metal plate on top, then the levers are held on by the springs.
Aug 05, 2009 | Brother Office Equipment & Supplies
Dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Jul 06, 2009 | Dell 1815dn All-In-One Laser Printer
Will not print and keep getting paper thickness error
Did you try moving the paper thickness lever (blue lever on top of the print cartridge holder)? It should be all the way to the left when you start--if it needs to be adjusted the printer message will let you know.
Jun 27, 2009 | Canon i850 InkJet Photo Printer
I have a Brother MFC-240C printer and need to refill my yellow ink cartridge but don't know how to. I have misplaced the instructions that came with the refillable ink bottles. Can anyone help me.
YOU are NOT SUPPOSED to "refill" the actual ink cartridges, but replace them with new ones. If you need to know how to replace this ink cartridge (I have this machine too) you just pop open the front rigth side panel and then pull the little plastic purple lever down in front of the YELLOW cartrdige which is labeled with a Y on the pull down cover in front of it, and pull out the old one to dispose of it, take the cap off the new one and push it in-the direction the arrow on the cartridge is facing until it clicks and the purple plastic piece locks it in, then shut the cover and the machine will do a "cleaning" and then you will be ready to print.
Feb 22, 2009 | Brother MFC-3240C All-In-One InkJet...
Dell 3100 error 010-397 restart and reseat fuser roll
We had the same problem. I loosened the levers that hold the fuser in place, and the one on the left side (as you face the printer) came out. When I put it back in, it didn't click into place all the way and the error message came up. I pushed down slightly on the fuser, then pushed the lever toward the back of the unit about as hard as I dared until it clicked back into place. That locked the fuser into place properly and resolved the problem.
Jul 05, 2008 | Dell 3100cn Laser Printer
Brother MFC 1950MC Printer Logo
135 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
