Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
On and off switch doesn't work anymore...
On my television the red(off) and the green(0n) switch won't work correctly. When you turn in on, it automatically shuts off.
  • jjonessb65 Jun 22, 2008
    Is there a place to take the t.v. I don't have electronic tech people available.
  • jjonessb65 Jun 28, 2008
    I am going to call the company and ask for help. I will let you know what happens. Thanks a million.
    Guru:
  • 1,894 Answers
Then u can better call ur company and ask them to send a tech for ur help sir
Posted on Jun 22, 2008
  • 6,487 Answers
Base from what you have said there's a possibility that the circuitry of the on/off switch has gone bad so if you know something about electronics you can try opening it up so you can see it, but I'm suggesting you to take it to a repair center near you and let a professional do it for you for yiour own safety also..
Good luck.........
  • Mark Gil
    Mark Gil Jun 22, 2008
    This maybe the problem the front panel plastic pivot is broken or the little tact switch itself is defective. In either case, you will need to slide out hte main board and remove the front panel PC board.
  • Mark Gil
    Try checking this site and check if its near to you they can help you for this http://www.freewebs.com/ramtv/
    President:
  • 624 Answers
This is most likely an electrical problem in the power supply, with the most likely culprit being this voltage regulator IC part number STK392-110
It is also very likely that you may have some open resistors and dry capacitors in the power supply.
Just in case the problem is something to do with the Microprocessor having some confusion you can do this.
You can try unplugging the TV for a few hours and then plug it back in and turn it on. This resets the microprocessor, and if the problem is that, it should turn back on, but I would not count on that working. But it is worth trying since it cost nothing and is easy to do.
Without the proper equipment and troubleshooting skills you will not be able to repair it yourself. It would take a couple of hours for a well trained electronic technician to complete this repair.
I hope you have found this helpful, and if you plan on fixing it yourself let me know and I can offer you some helpful advice on what to look for. but if you are not experienced at electronic repairs, it is not a good idea to try and do this yourself, I have seen many people try and cause more problems than they started with. The end result being that they ended up spending even more money than they really needed to.
  • Dave DeGain
    Dave DeGain Jun 22, 2008
    To find the nearest Akai service center to your home, please visit this website and enter your zip code. They will locate the closest one to you.
    http://www.akaiusa.com/service_locator.a...
    Brigadier General:
  • 6,966 Answers
Often, this is indicative that the internal protection circuitry is engaging, that is once you powered it up, the built-in diagnostics sensing something is wrong and therefore automatically shutdown the unit.
Not unless you are comfortable working with electronic circuitry and components, it is perhaps best to seek the services of a qualified professional.
Pls post back for any developments or should you need additional information.
good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Jun 22, 2008
    Hi again,
    Initially, pls try a hard reset; that is unplug from the mains for a number of hours. If the unit resets itself and revert to factory default, then it will power up. Of course this is assuming that there are no hardware defects but a systems glitch. Further a hard reset reverts all configuration and settings.
    Should this be not corrective, then access to a service manual would be advantageous for any diagnosis/repairs.
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
When turning television on the power light flashes green 3x then red 3x the television does not come on lamp is still good
Thats indicating that either the lamp door isnt contacting its safety interlock switch, or the lamp isnt seated correctly. They will both throw a 3 blink error code.
Aug 09, 2011 | Sony KDF-50E2000 50" HDTV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
When I use the HD input on my mitsubishi, everything on the screen is green???
When your picture has a green shade to it when connected through component video cables(red,blue,green) that indicates that you have the red and blue switched around at one end, since you have a picture, that indicates that the green cable is hooked up correctly, if the picture color isn't corrected after you make the switch, then make sure you don't have a bad cable.(it happens more often than you think) Good luck !
Jan 05, 2010 | Mitsubishi WS-65809 65" Rear Projection...
My rca big screen hdtv's screen is messed up
it is the convergence.normally can be fixed by replacing a fuse
May 29, 2009 | RCA R52WM24 52" HDTV Projection Television
Picture turns to red & green and becomes blurred.
This is likely solder connections cracking on your convergence ICs. If you can bump the tv and it goes back to normal, it just needs resoldering, but if it doesn't, then it needs the ICs replaced. If the convergence is out, you will see a bowed picture and the red, green, and blue will be separated. Worth repairing if you can find a company to do it affordably, I can help you repair yourself if you have disassembly and soldering skills.
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Green picture
The red tube is bad . There are three crt tubes in set red green and blue. your red tube is bad. cost if you where to bring it in to tv shop would be around 450.00 and tubes
are sometime not in stock anymore..
i hope this helps doctor video
Apr 21, 2008 | Akai PT5598HD 55" Rear Projection...
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Akai Televison & Video Experts
Dave Naylor
Dave Naylor
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
