Zenith dvd player dvc2515 had movie dvd stuck in it...
We were watching a movie with our dvd player...zenith dvc2515...all of a sudden...movie froze....remote control doesnt make any action at all...cant fast forward...stop...remove disc...nothing works...we tried manually on dvd player to touch all buttons...no results....dvd still stuck in player....my husband unplugged the dvd player...then plugged it back in and turned it back...no results...dvd player still has dvd player stuck..help....jack and pam winter
  • rvmagic Mar 02, 2009
    I'm on my 4th or 5th dvd player, they seem to be working fine, that is until a few weeks after the warranty expires. Then it will freeze in the middle of a program, skip to the next chapter, or not read the disk at the start. I tried cleaning both disk and player, unplugging the player, and nothing works. The problem then becomes progressively annoying until the player's motor becomes loud and I finally toss the player into the landfill and go buy another. This has happened with most brands of players over the last year, ranging from the expensive disk burners to the cheapest players from WalMart, costing as much as a movie ticket for 2 or 3 adults. Whatever happened to respect for consumers and concern for the environment?
  • Anonymous May 03, 2009
    Koss Home Theater freezes or skips. You can't watch the movie because it goes from the beginning to the middle to the end--very frustrating. Going to the scean menu seems to work sometimes. Very frustrating. Bought a new Toshiba with 1080P UPconversion today and I'll try to patch the two together so that the speakers run through Koss and use HDMI through Toshiba HD tv and Toshiba 1080P. Learned my lesson about electronics--after a year or two they go into the landfill. From now on I'm buying a relatively inexpensive one with some bells and whistles to keep up with technology. Plastic isn't so fantastic.
  • 30 Answers
SOURCE: My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Posted on Mar 27, 2006
SOURCE: A DVD got stuck in the dvd player
unplug dvd player, hold down open button, then while continuing to hold down open button, plug dvd player back in.
Posted on Mar 16, 2008
SOURCE: Unit totally locked up
I called the secondary 800# as the number in the manual has a recording for "if you are calling about the drc8335 call 877-805-0519" how bout it? A separate number just for this unit?
The guy said to unplug the unit for at least 30 MINUTES & that I would have to rescan in all the channels I have spent alot of time scanning in by rotation of the antenna. Geezzz I wish I had returned it to the store before the 90days were up... (price has dropped below $150 was 219 last year?)
Posted on Mar 19, 2008
SOURCE: dvd player stuck in 'demo repeat mode'
Hold the Stop button for 5 long seconds
Posted on May 06, 2008
SOURCE: Disc Error - Playback Feature not Available on this Disc
I think I figured it out...at least mine is working now anyways and it hasn't worked in 2 years! I got the remote out, pushed setup in dvd mode and initialize and now it works
Posted on Jan 07, 2009
How do I get back to the Meue that I will show progressive scan mode. to remove progressive scan mode, because its stuck on the DVD, whereas we can't see the movie but we can hear the sound. I tried to...
1) Remove any DVD that may be inside
2) Press AND Hold Stop Button (on front of Player) for 5 or more seconds
3) All Done - This will have reset player back to Interlaced Mode and you can now see your DVD!
Feb 15, 2011 | Zenith XBV343 DVD Player/VCR
Region free?
This will fix change the dvb312 to region free for an individual dvd. Must be repeated each time you want region free.
Insert the different region dvd.
A message will appear on the screen "check region" (or something like that)
On you remote control press the "display" button. Quickly press the number buttons, "1", "2" and "3". It should now let you play the dvd.
It has worked on mine which was bought in 2003. We have watched a ton of region 2 movies. Good luck.
Jan 31, 2010 | Zenith DVB312 DVD Player
DVD stopped working and won't start again
Try cleaning the lense. Use a q-tip and some rubbing alcohol.
Dec 02, 2009 | Zenith DVP615 Portable DVD Player
I HAVE DVP615 AND PLAYED THE MOVIE W. 4 TIMES 4 DIFFRETN COPIES AND WILL NOT GO PAST SCENE 19 OUT OF 25? NO ONE SEEMS TO KNOW Y?
You can call Zenith customer service and tell them the model number of you DVD player and ask them if this is a know problem for the player. If not you can ask them what may be the problem with the player or the movie that the player cannot play the movie. The telephone number for the Zenith customer support is 1-800-243-0000. I hope this information helps you with your problem.
Apr 17, 2009 | Zenith DVP615 Portable DVD Player
I have an old Zenith Digital Surround System the Receivver is a Model Z763B with a DVD Player/Recorder connected. When I play a DVD or VHS the sound can be heard through the TV and the Sound System,...
I have the same A/V receiver and in my setup there is an audio output (red and white able) coming from DVD player directly into Zenith Z763B. The video from DVD Player goes to TV input (yellow cable).
There might be alternatives to the setup mentioned above but I like to watch movie in a surround sound, rather than output from TV.
Jan 07, 2009 | Audio Players & Recorders
Recorded dvd's won't play in another dvr
The problem is not the dvds themselfs it is the other play that you are trying to play them in (some players do not play DVD- and DVD+ or any other of self recorded disks) Look on the players box to see all what types of disks it can play!
Please rate answer and help keep this site free
Jan 03, 2009 | Zenith XBR716
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Zenith XBR411 DVD Recorder/VCR Combo Problem
I have the XBR616 zenith combo.
If your dead set on initializing your dvds, I can try to
do one in my dvd player to see if it works, then send it back to you. I can't guarantee anything, my player is a bit fussy, but I don't mind helping you.
If so, let me know
Oct 28, 2008 | Zenith XBR411 DVD Recorder/VCR
Zenith DVD Player--DVB410/ZND400
I got two new disks to-day with pictures taken from 35mm slides. They will not play on my zenith znd400 dvd player. I wonder why??????
May 10, 2008 | Zenith DVB412 DVD Player
Progressive scan mode will not disable
Hi, you must hold 1st remove the disc (if you have one in) then hold down the STOP which is just under the RECORD button. Hold it for about 6 to 8 seconds. That should clear it.
Good luck
trestaris
Dec 09, 2007 | Zenith ZHX-313 System
Televison & Video Logo
287 people viewed this question
Top Televison & Video Experts
