Question about Dishwashers
I am installing a dishwasher. When I went to wire I had only two wires a white and blue comming through the house wiring and a white and black from the dishwasher. Does blue go to black. White to white and how do I gound it Thanks George
    Habit-Forming:
  • 34 Answers
If you have a volt/ohm meter you can check for Power on the Blue wire. Or you can open the face of your fuse box and look to make sure the Blue wire is connected to the fuse. If it is, just hook up your Black from dishwasher to the blue from house. White to White ( Neutral). There is no real way to ground the dishwasher if your house wiring is a 2 wire (old) system. You shouldn't have a shock hazard if the wires are in the junction box for the dishwasher.
Bill
Posted on Jun 22, 2008
Light turns on but fan doesn't. This fan had a
You wired it correctly . It might be your fan's on &off switch that went out or your motor.
Sep 01, 2011 | Hampton Bay Dryers
I'm trying to install this for our outdoor Christmas lights. The wall switch box has 1 black, 1 white, and 1 bare (ground). Where do I connect the red "timer" wire from the timer unit? When I...
Single pole application, red wire is capped off.
http://waterheatertimer.org/ST01C-program.html#ST01C
That being said, you still have to connect Blue and Black wires correctly.
Switch has two wires, if you do not know which wire is which, follow instructions below.
Connect Blue and Black to either wire.
Turn on power.
Push ON-OFF button.
If lights work, then timer is wired correctly.
If lights don't work, then reverse Blue and Black.
Be sure outdoor bulb is working.
I have a long story about that, and tested every wire and breaker ... and bulb was burned out.
Nov 28, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hello, I have to install a Hunter universal remote receiver, Model 27185 toa Hampton Bay ceiling fan w. light, Model 468-282 today. The receiver has 5 wires, red to light, black to fan, a live black to...
Red from receiver to blue light feed. Black from receiver to black feed to fan. White common from receiver to ground.(bare copper)
Black from receiver (hot) live in, to black from household wiring switch. Common in from receiver to neutral (white ) from house (switch.)
Sep 26, 2010 | Hunter Ceiling Fan Remote Receiver...
Am installing a ceiling fan and do not have the installation instructions. The fan has a black wire (labeled Motor), a white wire (labeled Neutral) and a blue wire (labeled Light). What is the proper...
When dealing with older houses, you run into this a lot, but the somewhat newer houses will actually have the 3 wires to hook up the ceiling fans. You can still use your 2 wires, but you will have to double up the motor and light wires. Wire nut the Black and Blue wires together with your Black wire from the house, and the White wires will be tied together for your neutrals. You should also have a green ground wire also, be sure to hook that to a ground in the house too. Hope this helps!
Aug 04, 2010 | Heating & Cooling
Just tried to install the fan and light, it doesn't work when power is connected. I have 2 white house wires, none black. I have rechecked the connections, no power to the fan
the white wires are returns they dont supply power .. you may have to take the fan back down in order to find the black or red wire that supplys AC power .. a red wire would come from a wall switch .. the black wire would usually be 120 VAC .. be careful .. you must first turn off power before working with that live wire .. the white wires are always paired with a black wire and a bare wire (safety ground) .. perhaps the black wire just got covered up when the fan was installed .. the black (or red) house wire should be connected to the black and blue wires of the fan .. the white wires should all be connected together .. the bare wire should be attached to the green wire or bolted to the fan housing ..
Jun 22, 2010 | Hunter (25417) Ceiling Fan
I was given a dishwasher and need to know how to install has only two wires
The wires on the Dishwasher should be Black and White
Black Wire is the Line or HOT Wire
White Wire is the Neutral Wire
Green Wire From the House goes to the Frame of the Dishwasher.
There might be a screw in the box area that is conected to the frame of the dishwasher and this will be the ground. ((((( The metal frame of the Dishwasher ))))
Feb 21, 2010 | Dishwashers
I am having trouble installing the wiring with my westinghouse. I don't know how to match up the wires. The Westinghouse has black, white, blue, and green wires, and my house wiring is purple, yellow and...
At the fan green is ground, blue is to turn on the fan, black turns on the light. I believe at your house wiring white is neutral and goes to the white in the fan. The purple and yellow are to switch on the fixtures, you can connect the purple to the blue, and the yellow to the black.
Oct 27, 2009 | Westinghouse Contempra Trio 42" Ceiling...
Sidewinder Fan Works but not the Light
As you were assembling the wire from the fan motor to the house wiring, there should have been two wires labled. One would have been labeled "FAN" and the other "LIGHT". To properly attach the wires, (be sure the power is off) twist the thin labeled black (FAN) and blue (LIGHT) wires together. Now attach those two twisted wires to the black house wiring with one of the supplied wiring cap. Finally attach the thin white wire to the white house wire with supplied wiring cap. Your fan is now ready for operation. If you had performed all these steps when you first assembled the fan, then the thin black wire going to the fan has come loose. Should your ceiling fan still not run after all that, then it's time to return it where you bought it because either the pull chain switch is defective or the manufacturer produced a defective piece of merchandise. If you found any of my suggestions to be helpfull, please rate my solution. Thanks D. Lange
Apr 19, 2009 | Hampton Bay Sidewinder 04890 Ceiling Fan
Wiring problems
The only thing which goes to the house's white wire is the fan's white wire.
Both the black and blue wires from the fan (black for fan motor, blue for light kit) go to the black house wire.
Anything else could result in a fire, a melting of internal parts, or a massive electrical explosion arc. The owner's manual is very clear about how the fan is supposed to be wired, and you voided the warranty by going against it.
You may have blown a fuse or a circuit breaker, or you may have blown something within the fan, or your house may be wired in series (very unlikely) in which case you need a new separate wire run for the light kit.
I hope this helps! If you have any other questions, feel free to ask!
Apr 17, 2008 | Hampton Bay 24002 Ceiling Fan
Dishwashers Logo
179 people viewed this question
Top Dishwashers Experts
