Question about Zenith P42W34P 42 in. EDTV-Ready Plasma Television
Zenith P42W24B Hello. I bought this television in January 2004 with a 4 year Warranty from Best Buy. Of Course, the Warranty expired 5 months ago and when I was watching TV last night it shut itself off. I had just gotten up from the couch so I thought that I hit something on the remote. I haven't been able to get it to turn on since. The TV clicks (as it normally would when it is turned on) and the red light at the bottom of the TV turns green. About 5 seconds later, you can hear it click again (as it normally would when it is turned off) and the light turns red again. Do you have any idea of what could be causing this problem?
  • littlechina1 Dec 07, 2009
    I posted this problem a year ago and I have not fixed the television. I am going to sell it as is and I was wondering if someone could give me any information on what the issue could be.
    Problem Solver:
  • 11 Answers
I had the exact same problem with mine. The TV clicks normally and the red light at the bottom of the TV turns green. About 5 seconds later it clicks again and the light turns red again.
I replaced the YSUS board and now the tv powers on no problem.
Posted on Jan 13, 2010
  • Zenith Master
  • 5,568 Answers
This behavior may be the power supply but that may not be the problem.
Modern power supplies are designed to shut down if the current drawn exceeds the design level which indicates that something the supply services has died.
For gear made in the period of 2003-2006 and stock that is still on hand from that period, may contain electroytic capacitors that have defective electrolyte, a chemical used in the manufacture of higher value capacitors.
The electrolyte was made from a stolen Japanese formula and improperly cloned in . . . where else? China.
There is no way to identify the problem parts besides the date code if present.
There are tons of electronic devices in service that will die due to this problem.
If you are adventurous, you might pull the plug on the set, gain access to the innards, and with good light, inspect any boards inside.
You are looking for components that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solde side.
This same type of component in smalled dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many (not all) will show signs of pregnancy when they fail, bulging unnaturally when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, an plus/minus number lying about the precision.
Some also have a date code (rarer) that will look like four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006.
Posted on Jul 09, 2008
Bought a 32 inch elememt television 5 months ago stopped working november 22,2015 before the big game. Past 90 day warranty. Are there any recalls on element televisions
Probably not. Why do you think they only offer a 90-day warranty? Even the poorest quality electronics normally offer a one year parts and labor warranty. To have only 90 days coverage is a big red flag that says "Don't buy me!"
Nov 23, 2015 | Element Televison & Video
Iphone serial number DNPLRD7LFFFR
  • General information
  • Factory: DNP - China, Chengdu (Foxconn)
  • Year: 2013
  • Week: 48 (25.11 - 01.12)
  • Age: 11 month
  • Size, weight and color
  • Color: Space Gray
  • Sizes: height: 123.8 mm; width: 58.6 mm; depth: 7.6 mm
  • Weight: 112 gr
  • Warranty Info
  • Activated: Yes
  • Status: Extended Warranty AppleCare+
  • Expiration Date: January 18 2016
  • SIM Lock
  • Baseband version: 1.02.02* *Baseband firmware version at the time of purchase
Oct 07, 2014 | Apple iPhone 5
HELLO I BOUGHT A 60 INCH SAMSUNG SMART TV ESUN8000, 6 MONTHS AGO, AND I NOTICE THAT IT HAS 3 WHITE DOTS. WHAT CAN BE THE CAUSE OF THE PROBLEM? I BOUGHT THE TV AT BEST BUY, DO YOU THINK THAT THEY CAN H
sound like you have samsungs dlp white spots plague, which just gets worst. samsung are aware of the problem, so you need to get in touch under the warranty.
Nov 25, 2013 | Sony KDF-42WE655 Television
The SONY LCD TV is 2 1/2 Years old about 6 months ago I noticed a very light pink 3in vertical line, now after the tv is on for about 30 to 45 min the line is black. does any one have a clue how to fix...
The line or dots on an LCD screen are because of dead pixels and tolerable upto a certain limit as per policy of the manufacturer. But line is not permissible and should be changed in the warranty support. The isssue you are reporting is the vertical line and the the film is to be changed. So if the set is not in warranty it might be a big expense as there is no way to fix it at home.
Thanks
Oct 07, 2010 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
Dec 18, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Insignia(samsung) 50" plasma Vertical red lines
I would take it back. I know from purchasing an Insignia LCD from them a while back, the TV just died after about 4 or 5 months. They ended up offering me another TV or with store credit. I took the store credit and chose another TV. I also did not have a warranty. I was told since it was Insignia (which is a Best Buy house brand) that replacing it was not a problem. Good luck.
Nov 25, 2008 | Samsung Televison & Video
TV warranty
Hi gince10,
I am sorry to hear that you are having trouble with your television. If you have enough information about the purchase, we may be able to locate the receipt for you. Simply visit your local store or call 1-888-BEST BUY™ (1-888-237-8289) for assistance.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 30, 2008 | Televison & Video
Vertical Lines
Sounds like pixel problems, this could be a bad panel or board inside tv. I would contact manufacturer and see if they have policy with bad pixel panel. Even with out of warranty try anyways.
Jan 04, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Picture black- sound ok
If you have audio but no on screen display, then the problem is likely in the Video Drive Board.
Mar 12, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith P42W34P 42 in. EDTV-Ready Plasma Television Logo
153 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
