Question about Dual XDVD8181 Car Video Player
Tried the code an it did not work
Are you using the OK button as the enter button. An if so is there any other code I can try..
  • 1 more comment
  • oscarmyer Jun 30, 2008
    i have a dvd dual xdvd8181 when i hook it up it says enter code does anybody outthere knows what the code could be PLEASE help me
  • wstakes Aug 03, 2008
    i have the same problem. i was moving it from one car to another and it locked its self. i never went in and changed the code on it and the factory 0000 doesnt work. I am sure there is an over ride code or a reset button or something. Please if someone knows, please let me know!!! my $300 screen will be worth less if i dont get it to work. Thanks
  • oscarmyer May 11, 2010
    i have a dual car dvd player dual xdvd 8181 i got it on ebay when i hook it up it says enter a code does anybody outthere knows what the code could be HELP ME PLEASE
I called tech support and they said to hold in the mute button then hold in the power button at the same time for about 12 seconds. after that, a new screen should come up and the code is 122164. i have not been able to get it to work as everytime i hold in the mute and power button, it shut the unit off. i thought i would tell you this incase you can get it to work. let me know how it turns out.
Posted on Aug 05, 2008
OK button not working. What do I do?
Try to connect external keyboard then press OK button. It may work if it is a case of button.
Oct 04, 2016 | Computers & Internet
I FORGOT MY NOKIA 5030c-2 security code
Ok so the keys and button sequence which you have done seems to be how to do a hard reset on your phone, the easiest way to get back into your phone is to enter the security code wrong several times until it says phone locked emergency calls only please enter a PUK code which is your personal unlocking code for your phone. You will have to contact your network provider for this though.
Jan 27, 2015 | Nokia Cell Phones
Where is the enter button on 6-in-1 remote control
There is no enter button. Use OK button instead.
Mar 18, 2013 | Televison & Video
I am having problems with my PS D7360. Error code 0xc18a0306 keeps coming up. I have tried the pineworks suggestion but it did not work. The printer has been sitting for a while.
Found this here it's worth a shot. http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Ink-System-Failure-C6180-error-0xc18a0306/td-p/161866
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
May 28, 2011 | HP Photosmart D7360 All-In-One InkJet...
Region unlock a Sony DVP-SR500H
Ok here's what I've figured out for Sony dvp sr500h...
To get to the hidden menu, you need to start with the DVD player power OFF
then hit
TOP MENU
CLEAR
POWER (to turn the dvd player on)
and you should now see the hidden menu
then go to option 2
then option 4
then this is as far as I get...you can enter codes here but none I've tried have worked....
the ones I've tried so far are 2812, 34570, and 12450
if anyone can figure out the correct code please post here.
Apr 27, 2011 | Sony DVP-SR500H DVD Player
I need the codes for a GE universal remote for a Daewoo TV
Welcome to FixYa!
You can try the following GE Universal Remote codes for Daewoo TV:
0130
0004
0009
0100
0005
0138
0043
0140
0039
0252
0279
0444
0080
0042
0058
0017
0010
0126
0018
0127
0019
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
If none of the codes listed work for your device try the Code Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER button (Should your remote model not have an ENTER button, then press the OK button.) The INDICATOR LIGHT will go off.
Thank you for using FixYa!
Have a great day.
Jas247
Apr 20, 2011 | Televison & Video
Att uverse remote will not turn power on/off on my olevia lt26hve tv Tried numerous code from att and doesn't work
have you tried the auto code? press tv ok together... 4 top lights will flash twice...enter 922.. tv light will flash twice... press and hold PLAY button until tv shuts off.... that should do it...(80% of the times it works... if not.. there will be no code available...
GOOD LUCK !
Jan 16, 2010 | Televison & Video
E- brake by-pass code
on the 9101 the enter button is ok make sure you use a real dvd no bootleg
May 30, 2009 | Dual XDVD8170 Car DVD Player
Nokia 1110i problem , unlocking the code
hi sir..
finnaly press the * and ok button allong with c. button if it does not work. u need to flash the phone.
thank u sir
i am there for ur assistance.
Sep 01, 2008 | Nokia 1110i Cellular Phone
Won't Work
I also have a Jumbo remote (the one with the coloured buttons on) and what a load of rubbish it is. The instructions are quite simply wrong!!! To pre-load a code press the device button you want (E.G. TV) and then press and hold the SET key until it is constantly RED. Then enter the 4 digit code you want and then press the OK key (despite what the instructions say this is the way to program the code).
To perform a SEARCH forget the instructins and follow these.. first press the device key you want (E.G. TV) and then press and hold the SET key until it is constantly RED. Then press the POWER OFF key and sit back and the remote will cycle through the various (and limited) codes it has, each time a code is tried out the RED LED light will blink a couple of times.
WHEN AND IF your device turns off (presuming it was switched on) then press the OK key to store the code.
To find out what code a device has stored against it press the device key you want and with it pressed down press the 1 key to find out the first digit, the 2 key to find out the 2nd digit etc.
In summary, the jumbo is a good gag, but is not practical, not useful, not easy to use, not supported and in general quite rubbish.
Dec 26, 2007 | Televison & Video
Dual XDVD8181 Car Video Player Logo
63 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
