Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Broken TV Its mainly the green one the red is a little off too but i think if the green one was fixed it would probably be ok
  • RCA Master
  • 8,617 Answers
If its only one color it may just need the two amps for that color, or if youre not good with soldering the Convergence amp board being replaced should take care of it. If you need any more assistance please let me know.
Posted on Jun 22, 2008
About the Sony Bravia Kdl55hx800 55" Lcd Tv
The 12 volts comes FROM the power supply board.
TV Parts Universal TV Stands DLP Chips ShopJimmy Go to this web site. You will find repair parts kits as well as complete boards there.
Dec 31, 2014 | Sony Bravia Kdl55hx800 55" Lcd Tv
Good older rca tv favors blue green, red is weak. tint function doesent help this problem is there an adjustment inside?, where, turn down green blue or turn up red? jm
Hello; The red probably got low over a long period of time due to only one thing. The CRT/ Picture tube is getting weak and cost much more than the set sold for. The adjustments may only help a little and the set will get worse. These adjustments are done on your remote control with service menu accessed. You will need a Service Manual for instructions to do this, but I think it's time for another set. John
Apr 25, 2011 | RCA MM36100 36" TV
Green & red tint
Most likely nothing you can do to fix this. CRT TVs use 3 colors to make an image on the screen (Red, Green, and Blue). If you're only seeing red and green then chances are the blue has stopped working. You can replace certain parts in the TV but for a 27" TV you'll probably end up paying more for the repair than a new TV.
I don't recommend taking the cover off and trying to fix TV yourself without training. CRTs have a lot of electricity stored in them (even after turned off) and you could accidentally electrocute yourself.
Apr 06, 2009 | Daewoo DTQ-27S5FC 27" TV
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Samsung sp42w4hb rear projector tv
Dave,,yes the tv is worth fixing the ic part you need is STK 392-010 and at this site i will give the link to they are 19.99 each you will need 2 if you get them at the link I posted you will also get free online tech support plus installation instructions with pictures
http://servicemanuals.vstore.ca/
Apr 09, 2008 | Televison & Video
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Prob. with aspect ratio
The key word here is dropped,was the unit ok before? how hard was it dropped? if the tv is only a 4:3 screen then it can not give you a 16:9 AR unless the dvd can change that, it probably has the main circuit board broken somewhere and it needs professional help.Let's hope is not major damage.
Sep 19, 2006 | JVC AV-27D303 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
